Having problems re-programming my HomeLink...
Hey guys,
We just had new garage door openers installed, and I'm having trouble programming the new codes in to my HomeLink. I cleared all of the previous codes. When I try to program the new ones, the HomeLink blinks as it would if it received the code, but it doesn't open the garage door. I think it's because the garage door openers are so new, but I think there is still a way to program it in. I just don't know what it is. Does anyone know how to program newer garage door openers into the HomeLink unit? Thanks, -Nick |
bump, anyone?
Make sure your doors are not code-hoppers.
If they are code-hoppers, how do I program them?
Thanks, -Nick |
uhh, read ur service manual cheif! look under "roaming codes" under the homelink system
Originally posted by 97blackSE uhh, read ur service manual cheif! look under "roaming codes" under the homelink system -Nick |
BUMP! Does anyone know how to program the HomeLink if the garage door opener has a rolling code?
Thanks, -Nick |
the owners manual tells u how, go to nissan-techinfo.com, or infinititechinfo.com cuz i know the infiniti one tells you how to do it with rolling codes
Both of those websites are to sell you owner's manuals. I have an owners manual for my 1997 Maxima and IT DOESN'T SAY ANYTHING ABOUT ROLLING CODES. I went to HomeLink.com and the programming instructions there also did not work. Can someone just tell me how to do it?
Thanks, -Nick |
hold on let me look in my manual
Originally posted by asf4life hold on let me look in my manual -Nick |
To operate your rolling code garage door
opener from your HomeLinkT Transmitter, follow these steps: 1. Program your hand held transmitter to the HomeLinkT Transmitter by following the procedures outlined above (if not yet programmed). 2. Program your garage door opener receiver to recognize your HomeLinkT Transmitter (The HomeLinkT Transmitter follows the same procedure to train to the receiver as your hand held transmitter did when it was first installed): a) Remove the cover panel from your garage door opener receiver. The receiver should be located by the garage door opener motor. b) Locate the training button on the garage door opener receiver. The exact location and color of the button may vary by garage door opener brand. If you have difficulty locating the training button, reference your garage door opener manual. If you have difficulty programming your garage door opener equipped with a rolling code system to recognize the HomeLinkT Transmitter with the rolling code feature, call INFINITI Consumer Affairs Department. c) Press the training button on the garage door opener receiver for 1 to 2 seconds. d) Return to the HomeLinkT Transmitter in the vehicle, and depress the programmed HomeLinkT button for the duration of the fast blink on the HomeLinkT Transmitter (1 to 2 seconds). Release the button, and repress to confirm that the system has trained. e) Your garage door opener should now recognize your HomeLinkT Transmitter. You may use either your HomeLinkT Transmitter or your original hand held transmitter to open your garage door. |
Yeah...that is the proecedure that I used all along and it didn't work. I just tried it again now. I guess my car doesn't support rolling codes.
-Nick |
u did all the steps, than if it still doesnt work call nissan consumer affaris
You are partially right. In 1997 there were rolling code garage door openers. But the 1997 maxima's homelink system did not support them. You need a 1998 and up visor with homelink. It hooks right up to your car and works with your new garage door opener.
I have a 1999 SE and a rolling code garage door opener and it works. :) Originally posted by Nick97SE Thanks. I have a feeling that my HomeLink doesn't support rolling codes. After all, my car was made in 1997. Back then, I don't think garage door openers even had rolling codes. -Nick |
© 2024 MH Sub I, LLC dba Internet Brands
