Popping sound when accelerating from a stop.
I have a '96 GXE auto. Around 110,000 miles or it. For the last 2 weeks, everytime I accelerate from a stop, there is a loud pop from the pass. side wheel. I recently put on a set of RX-7 wheels with 225/50/16 tires and new front rotors. I thought maybe I missed something or didn't get something tight but I just got done checking everything I could and everything is fine. I jacked the car up, took off the wheel, checked every bolt, moving part, etc. and couldn't find anything. Pulled it over the pit and yanked it up and down, pushed it forward and back. Nothing. Only does it when I've been driving, come to a complete stop and accelerate again. If I do a rolling stop, nothing. Has anybody had this problem or know what the fix is? It's really annoying.
Oh ya, I replaced the axles about 6-8 months ago and I've done all the turn in cirles tests to check the joints on the axle.
I'm have Sprint/Tokico suspension. Energy Suspension poly bushings. PR Poly Motor Mounts.
Re: Popping sound when accelerating from a stop.
Make sure your caliper pins aren't bent, and maybe regrease them.
Originally posted by Nismo
do you have CAI? I used to have a clink noise with cai since the lower pipe would bang on the fender when the engine rocks
Originally posted by Max4Speed
I have had this noise for an YEAR now. I have replaced all the shocks/suspension parts but still its there. I just try to ignore it :-(
Well, well, well.. look what we have here. I was just asking Ben about this noise yesterday, sinceI have it too. I have had this noise for a while now, and I have put a new wheel bearing in, new hub assumbley, new lower control arm, straightened all my rims, rebalanced tires, new strut mounts, FSB bushings, etc. and I still have the noise. Ben told me it could be an FSB bushing or a motor mount, and guess what it's not the FSB bushing. When I reinstalled my OEM ones yesterday I found that one of my ES endlink bushings was cracked and I thought I had the problem solved - but I've driven 60+ miles since and it's still there. So soon enough I hope to take that rear mount out (anyone know how hard this is?) and inspect it. Hopefully he is right and that is my problem. Hopefully.
-Cyrus
-Cyrus
-Cyrus
-Cyrus
Ohhhhh forgot to mention- do you have a FSTB? anyways I had a "chattering" noise before and it was because the AC line was rubbing up against my FSTB and it was up against it. check to see if the ac line is hitting it and try to bend the bracket away from it if it is. hope you find what your looking for
yeah, i have this problem too. for me what is was... when i put my CAI on i lost a screw to the plastic fender in the wheel well. so its kinda loose, so every time i would accelerate from a stop it would pop out of place for a second and the sound of plastic on the metal sounded like a popping noise
Current score: Bench grinder: 1, FSTB mount: 0
My car use to make this sound every once and a while and then it just sort of disappeared. I know exactly what kind of noise you're talking about too. I think the problem possibly lies in the strut mount or the coils of springs hitting one another (are yours wrapped good?).
Dave
Dave
I have this noise too and it bothers me because it sound so bad! Like I'm driving some piece of **** car. I actually get it going from a stop and sometimes just rolling at very low speed. At regular driving speed, the car is smooth with nary a foul sound.
I recently redid the front suspension with new mounts, new coil wraps and the sound is unabated. Like everyone else, everything looks fine! I was thinking about replacing the control arm but since Vyrus did that, I don't think I will. BTW, I hear it on the drivers side... It sounds like a metallic popping like it could be the coils interacting with the lower mount or something but I swear, everything is well wrapped!
This sound is really ****ing me off. I'm going to inspect the engine mount today and get back to you guys.. then I'll check the FSTB, fender rivets, and anything else you tell me. I've replace basically the entire right front suspension, and I still have this noise. Seems that I am not the only one tho, so it must be problem to do with the original equipment.
-Cyrus
-Cyrus
AaronL
08-08-2020 10:31 AM
Need help
23
10-02-2015 08:56 AM
DC_Juggernaut
09-28-2015 04:07 PM
