Electrical Problem? Help!
Guys my taillight bulb the 1157 bulb right above the reverse light constantly keeps going out the HIGH filament side, I've replaced 4 bulbs now! What's up with this it's ticking me off, I accidently once put in a 1156 bulb which took out the fuse but I replaced the fuse the same moment, so I doubt it's the fuse because all the other bulbs are working. And also my low filament side of my headlight went out while I was driving tonight, so I had to drive on with my Highbeams. What's up with all this???
No believe me everytime I put in a new bulb it's brand new. I spoke with my mechanic he said I might need a new socket. Is that easy to put in, and how can a socket go bad afterall?
The low filament side is working, for e.g. when the lights are on the bulb lights up, however, when I depress the brake pedal the bulb doesn't light up hence the high filament side not working. Could also be a result of the socket?
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
11-06-2015 02:34 PM
