My (fake) hyper grounds
Old 07-23-2003, 11:44 AM
I'm nutty for Nissans
JSutter's Avatar
I was reading an article in a truck mag, about the ground wires so I figured if the big boys were doing it, i'd at least try it. I had alot of Montster Cable 8 awg lying around so what the hell...it's free!
At the moment i grounded all the wire next to the 1st main ground.
I have 5 grounds (head, alternator, grounds near pass. headlight, above the fuel rail, and on the intake manifold). Anyway as of right now I don't see an improvement, but it may be where I did them or my cheap terminals. Oh well, at least it matches my gay red theme.
JSutter is offline
Old 07-23-2003, 11:48 AM
JSutter's Avatar
More pix
JSutter is offline
Old 07-23-2003, 01:09 PM
Mishmosh's Avatar
Very clean install! Color really matches well. Did you take out your intake system just to do the ground system?
Mishmosh is offline
Old 07-23-2003, 02:22 PM
JSutter's Avatar
Originally I took out the intake to clean the throttle body, but I ended up doing the groung wires too. If I was doing just the wires, I would at least take the filter out.
JSutter is offline
Old 07-23-2003, 03:04 PM
AllGo's Avatar
Not that you haven't done the electrical system some good but you are still limited to the current of the stock 4gauge wire going to your neg terminal. I would run another 4 gauge from your grounding point on the frame to the neg side of the battery and that would double the amount of amps able to travel the loop. I have my battery in the trunk so it is even more important for me to have this done.
AllGo is offline
06-06-2017 02:01 PM
09maxshawn11
09-30-2015 10:28 AM
Maxima Pride '07
09-12-2015 07:29 AM
Quick Reply: My (fake) hyper grounds
