First time w/ nitrous at the track, fried the clutch...need help!
Well i just came back from desoto speedway after running my car. It was my first try with my nitrous setup (50-shot, wet). Well, my first run i ran a 14.5@97, but noticed what i thought to be my tires spinning in every gear. Well, indeed, it turned out to be my clutch slightly slipping. So i run again about 1 hour later, and my clutch never really engaged, it pretty much spun the entire way, leading to only a 14.8@93.
Well, i figured my clutch would still be ok, but i went home anyways. I decided to punch it to see if the clutch was still slipping, and bam, completely slipped in a 1-2 shift. Its pretty much shot, no more racing... Now, my question is, i know theres alot of different clutches out there, im not looking for a racing clutch or something that will shatter my tranny, but i need something that will at least hold this 50-shot, later to be a 75-shot. Are there any clutches you guys can recommend that are running that much power?! Any sites, prices, experience and everything is appreciated. This is shiiiiiiity!!! :bawling: Eric |
i have an exedy and i should have nitrous going by the end of this coming week so i can let you know how that holds up
I'm using a ACT steet modified clutch. It hold a 50 shot with no problems.
act street (part number NM1-HDMM) would be a good one for the amount of power you were talking about. just don't be stupid with it (shifts). It lists for mid 300's , and can be purchased for upper 200's
good luck |
I love my EXEDY Stage one Clutch. I have no chatter or any problems with it. I am also running a fidanza flywheel and have not driveability issues. Though I am not running nitrous... I can chirp third if that helps...:laugh:
Originally posted by guestNX act street (part number NM1-HDMM) would be a good one for the amount of power you were talking about. just don't be stupid with it (shifts). It lists for mid 300's , and can be purchased for upper 200's good luck Eric |
Originally posted by EteRnity059 I love my EXEDY Stage one Clutch. I have no chatter or any problems with it. I am also running a fidanza flywheel and have not driveability issues. Though I am not running nitrous... I can chirp third if that helps...:laugh: Eric |
Originally posted by 99Maxima5sp whats the part number on that clutch?!? Eric |
i hear alot of good things about the act clutch, the exedy is the manufacturer of the OEM clutch
Eric you dumb kid, you will need 100hp/120tq via a 100 shot to keep up with MEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE.
MWUAHAHAHAHAHHAHAHAHAHAHHAAH :goofy: |
Originally posted by Craig Mack Eric you dumb kid, you will need 100hp/120tq via a 100 shot to keep up with MEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE. MWUAHAHAHAHAHHAHAHAHAHAHHAAH :goofy: And thanks eternity059...I look into that one... Eric |
well....well.....my penis is bigger than yours. AND i have a snail that makes weird chirping noises that attracts mondo attention.
Erics car with 50-75 shot of ***** juice, rice sauce, cheater gas < Craig Mack Blown at 10psi |
Hey now dont be bustin on people runnin nitrous. Call it all you want but when he beats you then you wont be talkin.
Originally posted by Keith97gxe Hey now dont be bustin on people runnin nitrous. Call it all you want but when he beats you then you wont be talkin. EXACTLY.... Eric |
im sure a stock clutch can easily handle a 50 shot
its just that yours is worn out... |
Originally posted by Craig Mack well....well.....my penis is bigger than yours. AND i have a snail that makes weird chirping noises that attracts mondo attention. Erics car with 50-75 shot of ***** juice, rice sauce, cheater gas < Craig Mack Blown at 10psi You still don't have one thing though that Nitrous gives you. Can you say torque? |
Originally posted by Keith97gxe Hey now dont be bustin on people runnin nitrous. Call it all you want but when he beats you then you wont be talkin. Yeah, if you don't have to stop to drop your tranny and clean out all the shavings from a burnt stock clutch like the originator of this thread. |
i ran 100 shot with my ACT.. my clutch is fine
too bad Craig's car will never see 385ft/lbs tq |
what about the regular duty Centerforce Clutch 30% more grip than stock, i thought I may try if one day!
There is also of just getting the clutch disc if you have a heavy enough pressure plate. I got mine for 89 bucks.
Originally posted by Ceasars Chariot what about the regular duty Centerforce Clutch 30% more grip than stock, i thought I may try if one day! make sure you buy 3 because they slip after 15k miles |
Originally posted by maxcross Yeah, if you don't have to stop to drop your tranny and clean out all the shavings from a burnt stock clutch like the originator of this thread. My tranny never broke or anything, i dunno what your talking about. All i mentioned is that i spun the sh!t outta it and i cant spray anymore. My car still works fine, i can drive it normally. I just need a new clutch... My tranny wont break on a 75-shot, let alone a 50-shot... Eric |
Originally posted by 99Maxima5sp My tranny never broke or anything, i dunno what your talking about. All i mentioned is that i spun the sh!t outta it and i cant spray anymore. My car still works fine, i can drive it normally. I just need a new clutch... My tranny wont break on a 75-shot, let alone a 50-shot... Eric don't be too confident in the tranny. mine broke and all I have is y-pipe and intake. |
Originally posted by UNCDooD don't be too confident in the tranny. mine broke and all I have is y-pipe and intake. Very true. God forbid anything like that happens, i do have an extended warranty that covers my engine and tranny. So hopefully it would be taken care of... Im also gonna look into whether or not it covers my clutch...never know... Eric |
Also, my dads insisting that i should just change my pressure plate and it will be all good. But those run upwards of 100 bucks, so shouldnt i just get an Exedy clutch kit and replace everything on one shot since i already have 88K on my tranny?!?!
Eric |
Originally posted by 99Maxima5sp Also, my dads insisting that i should just change my pressure plate and it will be all good. But those run upwards of 100 bucks, so shouldnt i just get an Exedy clutch kit and replace everything on one shot since i already have 88K on my tranny?!?! Eric |
Originally posted by 1FSTMAX Yeah replace everthing, and resurface the flywheel or replace it. About how much does resurfacing one cost?! <<New to the tranny stuff... Eric |
Originally posted by SprintMax i ran 100 shot with my ACT.. my clutch is fine too bad Craig's car will never see 385ft/lbs tq 1FSTMAX: http://images.cardomain.com/member_i...0_107_full.jpg Look at those two beasts leading the way, with all the small displacement rice behind them. True small block beasts with tiny blocks behind them. |
Originally posted by 99Maxima5sp About how much does resurfacing one cost?! <<New to the tranny stuff... Eric |
Originally posted by SprintMax i ran 100 shot with my ACT.. my clutch is fine too bad Craig's car will never see 385ft/lbs tq |
Originally posted by Craig Mack Did you ever get those dual exhausts? I remember you PM'ing me about it a while back. Let's see some pics...or do you still have a single fart-back? 1FSTMAX: Look at those two beasts leading the way, with all the small displacement rice behind them. True small block beasts with tiny blocks behind them. |
Post the video :jump:
Originally posted by Keith97gxe Post the video :jump: |
© 2024 MH Sub I, LLC dba Internet Brands
