belts whining
Originally Posted by sk24iam
I had my belts changed by jeff at max tuning about a month ago because they were whingin They were fine untill now, when I start the engine after not running it within an hour or so it whines.
When does it wine? When you step on the pedal or just when its idle? Because im trying to figure out why I have a humming noise coming from the ypipe i think. And my pedal is really soft when i press it down and i think i lost some low end, think its a leak?
i know where sl24iam is coming from...ever since i changed my alternator and had nissan change belts and make sure that everything was put back together, i have been getting that belt whine almost everytime i start the car and whenever it drops down to idle...its annoying as hell cause you lose LOTS of power when it happens, your lights are all dim and it makes a horribly loud noise.......i wish i knew what the fix is because whatever nissan did, didn't help my problem...however, the belt appears to have no wear on it....so maybe its something to do with the idler pulley?
Check the belt tension
http://www.cybrrpartspro.com/Manual%...delLookup.html
Select your "Year" and "model"
Look under "General Information & Maintenance"
Then under "Routine Maintenance and Tuneup"
Then "BELTS"
Then "BELTS"
http://www.cybrrpartspro.com/Manual...odelLookup.html
Then "BELTS"
Then "BELTS"
link didn't work. try again?
They probably just need to be tightened. They stretch a little bit after you run them for a while, but if you tighten it it'll be just fine. If you get it too tight, it won't squeak, but it'll mess up the bearings in the pulleys for things like ac or alt or ps and stuff.
James92SE
142
01-02-2024 09:23 AM
05' MaximaMan
10-08-2017 06:36 PM
