Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Driver's side headlight/wiring harness keeps burning out!! >=oT (https://maxima.org/forums/4th-generation-maxima-1995-1999/191758-drivers-side-headlight-wiring-harness-keeps-burning-out-ot.html)
Ukyo Nov 13, 2003 11:40 AM
My driver's side bulb or wiring harness keeps burning out... sometimes it's the bulb, sometimes it's the harness... but it's always the driver's side... can someone explain why that is? I was thinking of getting HID because i'm sick of replacing the parts but if it's burning out because of electric issues w/ the car then there is no point in getting HID because the bulbs and ballasts would be too expensive to replace all the time... need everyone's input... thanks
waveridr85 Nov 13, 2003 11:41 AM
your fuse maybe a hihger rating than it should be make sure drivers side and passenger side are the same. 0.02
Ukyo Nov 13, 2003 12:33 PM
Never thought of that... I figured only the correct fuse would work otherwise the light won't even turn on... but i'll check tonight... thanks!
Chunger Nov 13, 2003 12:56 PM
Solution is to use STOCK wattage bulbs...
You may even burn your H/L switch/stalk... It's a common problem in our cars.
1MAX2NV Nov 13, 2003 01:14 PM
Three solutions.
1. Go back to stock wattage bulb.
2. Ground the headlight sockets to a piece of metal near by. The shorter the ground the better it is. This will reduce the heat at the harness.
3. Get the headlight harness kit. Thicker wires.
