Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Suspension doesn't sound right (https://maxima.org/forums/4th-generation-maxima-1995-1999/193378-suspension-doesnt-sound-right.html)
808max Nov 23, 2003 11:17 AM
I'm running the Intrax springs and Tokiko blues in my max. I don't know why but something sounds loose whenever I hit bumps. I checked everything and the struts tops and mounts are all tight. I wonder if it is the spring? Anybody else have this problem? I am thinking of just dynamating everything in the trunk and interior so I don't here any noise already.
S103100F Feb 9, 2005 07:55 AM
did you fix your problem?
nismomax98 Feb 9, 2005 09:35 AM
i had same problem intrax do that u need to make sure the spring is not moving against the strut when i would turn it was moving and making anoying sound, just put some tape around the top and bottom few coils on the spring and make sure the spring sit in right position
