Freezing cold out and car won't start.
Old 12-03-2003, 07:42 AM
eelcram's Avatar
Does anybody know y my car won't start?? It's not the battery. Everything turns on, but the car just won't turn over. Something must've frozen over or something. I just can't figure out what. Can anyone help me with this problem?? Thanks.
eelcram is offline
Old 12-03-2003, 07:54 AM
maxcross's Avatar
is it attempting to start, and just sits there turning, or are you getting no function from the starter?
maxcross is offline
Old 12-03-2003, 08:17 AM
eelcram's Avatar
It seems like it's trying to crank, cause I hear a turning sound. But the whole car won't turn over.
eelcram is offline
Old 12-03-2003, 08:20 AM
Defacto's Avatar
it was so ******* cold this morning, i wouldn't be surprised if it's just the weather...
Defacto is offline
Old 12-03-2003, 08:33 AM
PoePoe2797's Avatar
Yup yup....18 degrees here. Try pressing the gas 1/3 the way down, and then try starting. This should give it a good amount of "kick" to start in cold weather.
Hey dude, I live in Newington, right on the WH border...if you want I can stop by and help ya out if your having trouble. IM me on AIM: PoePoe2797
PoePoe2797 is offline
Old 12-03-2003, 09:40 AM
johnnyo319's Avatar
My gf's max has the same problem.. She gives it a little gas and it starts.. Anyone know what is causing this?? Her dad said it had something to do with the fuel lines or injectors? Is that true?
johnnyo319 is offline
Old 12-03-2003, 10:11 AM
DaddyMac's Avatar
trust me you don't want "the whole car to turn over".
1-if the starter is good, the engine will turn. if so,
2-prime the fuel system.
DaddyMac is offline
Old 12-03-2003, 12:50 PM
Redlinemax Owner
Redmax's Avatar
your battery might have power, but not enough cold cranking amps for how cold it is , get a jump and then try again
Redmax is offline
Old 12-03-2003, 01:16 PM
Kevlo for President
Kevlo911's Avatar
put the key in the "on" position(dash lights up) for 15 sec and then try to start
Kevlo911 is offline
Old 12-03-2003, 03:04 PM
JBza's Avatar
Im having the same problem. Ever since it started to get really cold the max wont even turn over if it has sat for a while. I have to wait 15-20 seconds before the motor will turn over.
JBza is offline
Old 12-03-2003, 05:48 PM
Custom User Title
Nismo3112's Avatar
Try cleaning the TB, this was the case for me.
Nismo3112 is offline
Old 02-24-2009, 07:03 PM
closerpat@hotmail.com's Avatar
Maxima wont start in the cold
What exactly is a "TB" - sorry but I"m new at this and having the same problem, have tried everything, car just cranks but won't start, appreciate the help!
closerpat@hotmail.com is offline
Old 02-24-2009, 07:09 PM
Leo_Koneval's Avatar
Yeah my car is experiencing some of the more minor issues, like after it starts the RPM would all of a sudden drop and then go back up in the cold.
I would really love some input on this but I discovered that after you turn your key to ACC where all the lights are on, and then turn the key very slowly to START the car will start a lot faster compared to turning it fast. When I experimented one day and turned it extra slow the engine seemed like it flooded or something and would not start, and it took several tries before it started again, and since then I abandoned messing with the key. But does turning the key from ACC to start differently actually affect how your car starts? Sorry for asking a question in another person's thread.
Leo_Koneval is offline
Old 02-24-2009, 08:35 PM
komik's Avatar
TB = Throttle Body. It's at the end of the black hose opposite your airbox (or other intake). Loosen the hose clamp and pull the hose off and you'll see something like this:
Link: Cleaning Throttle Bodies
komik is offline
Old 02-24-2009, 09:26 PM
ajm8127's Avatar
To build fuel pressure?
I am interested because I notice in the cold, mine also has trouble starting.
ajm8127 is offline
Old 02-24-2009, 09:39 PM
x X CLoud X x's Avatar
this is a very common problem in alot of maxi's, for some reason the car struggles to turn on in freezing cold
for me i just give it slight gas as im turning it on, and it works everytime, on normal days it just turns on fine
x X CLoud X x is offline
Old 02-24-2009, 10:44 PM
trand71's Avatar
I've had the same problem in my car (last years winter it was -40 degrees). - since then i've added HEET to the gas tank and it cranks right up. You can get that at Wally World or any auto parts store. Add it to each fill up or so and you should be good.....
trand71 is offline
Old 02-24-2009, 11:39 PM
Bjs470's Avatar
Man I hate when that happens
Bjs470 is offline
Old 02-25-2009, 07:12 AM
Gotcha!
swatspyder's Avatar
from what other people have mentioned, it might be the gaskets shrinking in the cold and throwing off the fuel to air ratio
swatspyder is offline
Old 02-25-2009, 11:06 PM
The Godfather's Avatar
I think you are referring to the "ON" position. At this position, the fuel pump activates, and since you wait for a few seconds you can hear the fuel system priming. Hence, why you possibly get a better start rather than cranking the key straight to start. Just a thought.
The Godfather is offline
Old 02-26-2009, 06:57 PM
wcs1885's Avatar
I have a 1996 Maxima & I have issues during the cold winter days that it won't start up. Just give it a little gas and it should be fine. Personally, I turn it to the "on" and let it go "beep beep beep" for a few and then turn it over. My dad says it's probably the battery or starter. I don't know... but I've changed the battery a few times too.
wcs1885 is offline
Lakersallday24
06-16-2019 01:35 AM
Btheman80
05-01-2018 04:03 PM
BobMax
08-15-2015 12:35 PM
Balkins
08-12-2015 06:39 AM
kirkhilles
08-08-2015 10:53 AM
Quick Reply: Freezing cold out and car won't start.
