Front Doors Won't Fully Close
I have a 95 MAX SE. I noticed that my front two doors are slightly misalighned to the body of the car. Looks like the doors won't fully close and there is a very small gap. The wind noise is also very noticable when I travel above 70mph. Is there any easy fix to this problem?
Thanks for your input. |
Wierd....check the door panels, maybe they are not on properly...
Thanks for your input. Check your hinges for the door. that is the only major thing that will cause your problem. although, you can not visiably see if the hinges are bad... so see if they are loose. and if anything else, get new hinges and see if it solves your problem. :) -Chris |
| All times are GMT -7. The time now is 11:10 AM. |
