Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Trunk Release Won't Pop Thr Trunk (https://maxima.org/forums/4th-generation-maxima-1995-1999/199870-trunk-release-wont-pop-thr-trunk.html)
jstrife Dec 30, 2003 10:42 AM
When I hit the release from the remote or from the inside of the car, it will not release the trunk, I tried cleaning, and WD-40 to help it release smooth, but nothing. It releases fine when I put the key into the trunk though. Any ideas?
~J
slfalco Dec 30, 2003 10:45 AM
There is a little slide switch on the latch itself inside the trunk, used to prevent the remote operation. Check for this little switch, and move it to the other position. Mine was accidently moved once, same problem....
jstrife Dec 30, 2003 11:44 AM
Yeah, when it originally stopped working, I thought it might be that, but I tried both positions, and still nothing, I believe the up position is where it is sussposed to be for the trunk release to work. Another thing, sometimes when I press it about 8-10 times it will eventually work.
Thanks again
~J
WhiskeyJack Dec 30, 2003 12:20 PM
I've been experiencing this recently too. My latch wont stay in the 'up' position so neither my remote nor the switch in the door skin is working for me.
Any ideas?
Cheers,
Matt
WhiskeyJack Dec 31, 2003 08:42 AM
To The Top Please
2k3TitaniumSe Dec 31, 2003 10:34 AM
That happened to be too.
ttap97 Sep 11, 2012 12:24 AM
i have this same problem but the only way i can open it is having some one else pull on my spoiler while i repeatedly hit the trunk release.. and i still haven't found the answer why it wont pop up
Reality sucks Sep 11, 2012 12:53 PM
check the release cable at the lock on trunk lid, pull plastic cover off and make sure cable is attached good.I had to bend my bracket a tad, works perfect now.
2brosgixxer Sep 12, 2012 05:49 PM
Mine does that too once in a while. You can move the lock assembly by loosening the 2 10mm bolts and adjusting it. The lock assembly may be holding too tight when the trunk is closed. Back the bolts (not the lock on the trunk itself but the part that the trunk lock goes into) out a little and adjust and see if that helps you. Also make sure the piece that the cable goes into is not bent at all...mine was sligtly bent which also caused some problems.
AznRyan Sep 12, 2012 05:52 PM
Maybe someone spilled a slushey on it, making it stick
:hide:
