Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   What's a good flywheel clutch combo (https://maxima.org/forums/4th-generation-maxima-1995-1999/203710-whats-good-flywheel-clutch-combo.html)
maxedout95 Jan 18, 2004 11:33 AM
I need to buy a new clutch and might as well but the flywheel I was wandering what are the best one's to get?
99Maxima5sp Jan 18, 2004 11:38 AM
Question...
1) Are you or plan on being boosted/nitrous'd anytime soon?
If so, go with an Exedy Stage 1/ACT Stage 1 and a Fidanza flywheel. Have heard good things about that combo. My buddy MaxPowerX will be running that setup shortly. Im currently running an Exedy Stage 1 and i love it. But i dont go around ragging on it and such. You have to be careful with a clutch as powerful as this...
Now...if your NOT boosted/nitrous'd go with a stock clutch/fidanza or something of that extent. Theres absolutely no use for an Exedy/ACT if your all motor. You will never make enough power all motor to justify an Exedy/ACT over a stock one. Stick with a stocker and save your tranny some life. Just my advice, and im sure many will agree...
Eric
maxedout95 Jan 18, 2004 11:50 AM
I only have few bolt ons like a exhaust intake short shifter and that's about it and I'm not going with any boost cuz my car has over 178000 on it so I guess I just go with the stock clutch.
I was thinking about going with ACT stage 1 but now Im not sure what kinda of damage would I do to my tranny if I went with that?
Black95Se Jan 18, 2004 01:26 PM
I have had the ACT stage one on my car for about 20k and it is doing great. No tranny damage whatsoever. BTW it was installed around 100k and im at 119xxx now.
Nismo Jan 18, 2004 04:15 PM
just dont let nissan sell you the key value clutch
maxedout95 Jan 19, 2004 08:43 AM
Thanx for all of the advises but I figured out what was wrong with the gears.
My clutch reservoire was empty so I filled it up and now its going in perfectly.
Thanx :banghead:
cydrive Jan 19, 2004 09:33 AM
not sure if you've done this already, but if it was empty, you might want to bleed the clutch just incase you got some air in the system...just my $0.02
Black95Se Jan 19, 2004 10:17 AM
I agree. One morning I came out to the car to leave and when I pushed the clutch, BAM right to the floor. Needless to say I left 30 mins late cause I had to bleed the clutch.
Ian
Linkage23 Jan 19, 2004 11:05 AM
I have the usual bolt ons and I also got a ACT stage II with the Fidanza. I've been scorned by org members for doing this on a non-boosted Max but I am calling it a foundation to future mods. Either way, it is actually my favorite mod done to my Max. It grips instantly and the flywheel has a subtle pull. I have no problems yet and have put over 25k miles on it thuys far with no disappointment. So its up to you. I'm a huge fan of ACT clutches and the flywheel is a toss up. Fidanza is a well known produst so stick with what you know. Good luck...
-Lieb-
MTESNI419and1 Jan 19, 2004 03:20 PM
yeah you definatly should NOT get the key value. its god awful mine was replaced for free by the dealer and they put one in only like 10000 miles ago and it already started to slip on hard shifts into second or third
