Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   What's the best clutch? (https://maxima.org/forums/4th-generation-maxima-1995-1999/216606-whats-best-clutch.html)
amr1776 Mar 18, 2004 07:24 AM
I'm so fu{king ****ed...my clutch is getting soft again after only 40k miles...of course it could be all the racing :)
What's the best clutch for the 4th gen? Stock or aftermarket, and if aftermarket which one? I'm so sick of Nissan's jerky transmissions...
amr1776 Mar 18, 2004 09:13 AM
Bump......
car_boy_16 Mar 18, 2004 06:31 PM
A clutch disc with carbon or kevlar would do you well...dont forget to resurface ur flywheel - and stop racing so much.
XIMA96SE Mar 18, 2004 08:00 PM
What is the purpose for resurfacing a flywheel?
amr1776 Mar 18, 2004 09:16 PM
Thanks carboy...what's the best type of clutch that people here have and where was it purchased?
sryth Mar 19, 2004 02:06 AM
I've got an ACT and I like it a lot. It sucks in traffic, though. The pedal gets very heavy.
Resurfacing the flywheel will clean it up, get rid of hot-spots, and make it true. It's a good idea to do this whenever you change the clutch. At least get it checked out.
drewm Mar 19, 2004 02:27 AM
In order of recommendation:
http://maxmods.dyndns.org/index.php?MaximaClutches
I'd personally go for a spec clutch. I've never heard one complaint about them yet.
ManualMaxima Mar 19, 2004 03:29 AM
i think stock is the best, unless you have alot mor epower than stock going throught it i would omt even bother. ACT become very difficult to work with in traffic and is more choppy when dirving it slowly. Just go with stock, unless you have a bunch of mods where the gripping power wuld be needed.
GassyMax Mar 19, 2004 06:00 AM
i like my stock in terms of smootheness , but i get some slip at high rpm and racing, and that blows. also , im in pittsburgh now so i need a tough clutch to handle all the hills. ... how is the spec type 1 compared to stock ? there isnt much info on them. should i get stage 1 or 2 ?
amr1776 Mar 19, 2004 06:30 AM
Hey GassyMax...I'm from Coraopolis and I know what you mean about the hills...going up School St. is a ridicuous 40 degree angle. I'm thinking of getting the Kevlar stage 2.
Dave B Mar 19, 2004 07:42 AM
IMO, if you're not boosting then stock is best. I'm talking about the true OEM clutch too, not the crap $150 "blue" clutch kit Nissan will install when your original clutch wears out. The true OEM clutch has to be ordered in parts (ie pressure plate, TOB, clutch disk, etc) and will cost about $270. The blue kit will slip under high rpms and high rpm shifts, it's a fact. My stock clutch has ~105K miles with about 170 1/4 passes on it. It's never slipped once. I think the TOB and pressure plate may give up before the clutch disk does.
I would never recommend ACT or Exedy unless you plan on pushing much higher power. These clutches grab hard and can cause gear failures in 2, 3, and 4. If you choose to run one of these clutches then you'd better shift softly unless you want to risk replacing a tranny. These clutches are also not known for their reliability or driveability. I've read numerous posts on the Org about the clutch disk shredding with only 5-10K miles and clutch shutter is common.
Dave
flashover Mar 19, 2004 10:10 AM
Hey Dave- Like your car. Been reading and learning using you as a mode. Im happy to find you on this forum. I used to live in olathe, so that is how i found out about the Kansas City Maxima Club. I have a 96 SE that i love to death. It has many and many miles, but still kicks the shat out of pretty much any Honda here in Lincoln, NE. So, like most, my clutch is slipping. I was going to get an ACT, until i read you last comment. I only have Stillen-Hi-Flow, and UR UDP, being installed on Monday. Oh also a B&M short throw. NGK Iridium to boot. What do you think about the Spec Clutch? flashover41@hotmail Thanks- Mike
Dave B Mar 19, 2004 11:28 AM
Thanks for the comments on my car. As for the Spec clutch, I really haven't read much about it other than a few people buying them. I haven't heard about driveability or reliability. I've researched a lot about Maxima clutches and I know that I will be going with the OEM setup when mine gives out. It has strong clamping force without being violent, it's smooth, driveability is pretty good, and it appears it can take a lot of abuse. I should note that I don't do 4000rpm launches or shift hard/fast on the street. The only time I do those things is on the track and maybe that's why my OEM clutch has lasted so long.
Dave
GassyMax Mar 20, 2004 12:59 PM
is there any way to tell if you got the blue clutch or the oem original clutch ?
