Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Put rebuilt engine in...car won't start. (https://maxima.org/forums/4th-generation-maxima-1995-1999/219105-put-rebuilt-engine-car-wont-start.html)
SLC98Max Mar 30, 2004 09:28 AM
I rebuilt my engine because a butterfly valve screw from my MEVI destroyed it. Well now that the engine is in it won't start.
I have a few theories: first of all the gas has been in the tank for 11 months so I am thinking condensation and possibly the gas going bad to be my problem. I am going to drain it and put new stuff in.
I also may not have purged all the air from the fuel lines so I will try that again as well.
I checked for codes and only got an egr code that I'll worry about later.
My problem is I have already turned it over twice and I want to figure out what is wrong for sure before I turn it over again because the pre assembly lube I put in it is only good for so long. What other diagnostic tips can you give me before I turn it over again?
Stephen Max Mar 30, 2004 10:26 AM
Hmmm. Damaged crank or camshaft position sensor? That would probably throw a code, but it might not at first.
Difficult starting is caused by lack of fuel, lack of spark and spark at the wrong time. Check to make sure:
1. fuel lines hooked up correctly
2. fuel pressure
3. fuel flow into cylinders (you can check this by pulling plugs and cranking, you should smell gas being delivered)
4. plugs are sparking
5. ignition timing is correct (you can check base ignition timing with a timing light)
I wouldn't worry about the assembly lube. First of all, at the low cranking speed, the lube is not going to go away that fast and lubrication needs are not great. Secondly, the oil pump is going to be pumping, even at cranking speed.
SLC98Max Mar 30, 2004 10:36 AM
2. fuel pressure
Thanks for the reply. I will be draining the fuel tonight and then I will check for spark and fuel delivery.
One question though, I tried draining the fuel by connecting a hose on the fuel pump output and leading it to a gas can. I then turned the key to on expecting the pump to pump the fuel. It pumped for about a second and then turned off. It continued doing this every time I tried it. Is there a safety that won't allow the pump to pump when the engine isn't running or does it require a pressure in the return line? Is there a way to bypass either?
Stephen Max Mar 30, 2004 11:10 AM
That is normal behavior. If the car doesn't start up pretty quick, the fuel pump stops. It should pump enough to pressurize the fuel rail, though.
There is a way to run your fuel pump directly from the battery, but I am not going to recommend it. I have done it, though.
SLC98Max Mar 30, 2004 11:23 AM
This is exactly what I am planning on trying tonight. I am aware of the dangers and plan on taking every precaution. If you could pm me with which wires do what so I can run mine manually I would appreciate it. I don't have the wiring diagrams and will be using a multimeter unless you can help. Thanks in advance.
SLC98Max Apr 2, 2004 08:49 AM
Well I got the maxima running. I have to work out a few kinks but other than that it is running great. A big thanks to StephenMax for your help.
2naboy Apr 2, 2004 09:32 AM
Hey I had similar problems when I dropped my engine in but it was other problems. Its good to see that you got yours working. Are you going to the meet in tucson?
Stephen Max Apr 2, 2004 10:37 AM
Good deal. Did you determine what the problem was?
SLC98Max Apr 2, 2004 01:36 PM
I drained the fuel and then flushed the lines. I also manually pressurized the lines before I tried to start it and it worked great. I still have to fix an egr code but it is running great.
SkoorbMax Apr 2, 2004 04:08 PM
Awesome! Man, I get ****ed when a rebuilt computer won't start - I can only imagine the horror after rebuilding an engine and wondering why the darn thing won't :)
