Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   To those who've changed their parking side lamps to brigther - question!! (https://maxima.org/forums/4th-generation-maxima-1995-1999/221649-those-whove-changed-their-parking-side-lamps-brigther-question.html)
Boznian Apr 9, 2004 10:14 PM
- Yeah, as the subject states. When I tried to make my side lamps brighter, the bulbs would get extremely hot very quick. (I'm talking about the side lamps that are next to the headlights). For the people that changed theirs, did you have melted harnesses due to the temperature of the bulb, or did the fuse go out on you? Did you have nay problems at all.
I seem to have my lights on all the time - throughout the day as well! I'm afraid I will melt the housing/harness due to the increased temp.
Ed
MaximaTodd Apr 9, 2004 10:37 PM
since i made mine brighter about two months ago, i have had no problems at all. and i do a lot of night driving too. i dont think you have to worry about it melting anything.
naijai Apr 9, 2004 10:40 PM
i did mine since last year and no problems or anything so go for it
mansurxk Apr 9, 2004 11:27 PM
thers a 2 week old post that people DO have problems with the brightetend lights, people complained about cracks in different places, the extra generated heat does damage the housing
bluestealz Apr 9, 2004 11:52 PM
had mines brighter for about a year now and i have had no problem on my 97...
Tyrexx Apr 10, 2004 12:26 AM
no problem here, are you touching the bulb? The actual bulb gets VERY hot.
95seMax Apr 10, 2004 01:47 AM
wat is the bulb size for the parking side lamp
1157 or 1156?
felix Apr 10, 2004 07:05 AM
don't do it
Yep. Don't do it. The housing wasn't meant to withstand that kind of heat. It WILL eventually get small hairline cracks on the inside. Mine did. The mod is not worth it in my opinion. I ended up just unplugging those lights.
sagamax Apr 10, 2004 12:45 PM
i havnt had any problem
RA030726 Apr 10, 2004 01:04 PM
1157 or 1156?
the are 1157 for all 4th gens.
I did this to my 96 with no problems.
moose54 Apr 10, 2004 01:07 PM
Ed
Did you rewire or modify the bulb? I modified the bulb and haven't had any problems.
techie Apr 10, 2004 01:34 PM
You can put amber in there instead if you don't like the dull white look and brighter bulbs are giving you problems. If your corners are orange you might not like the amber with the orange, but if you do have clear corners with amber bulbs, it will match. I felt amber with the orange was better than the dim oem clearance lights next to hyper whites.
z32drifter Apr 10, 2004 01:35 PM
are you running both the bulb filiments?????? or just the brighter one?????? I have had this mod for close to 4yrs with no problem.... I rewired so the brighter filiment was on with the parking lights and the dimmer one is on with the turnsignal
Ludacris Apr 10, 2004 01:40 PM
I had the corner light next to the headlight running on the brighter filament for almost a year with no problems at all...now its rewired as my signal
NickStam Apr 10, 2004 03:34 PM
I've had this rewired for 4 yrs w/o a problem.
nismos14 Apr 10, 2004 03:45 PM
same here no problems, i've had mine for a while.
on a side note, z32drifter ur car's are sweet. the z32 rims look perfect on the max. you've done a damn good job with the z32 as well, any more info on it? and more on ur max? a website? more pics? anything?
:thumbsup: :thumbsup:
Kevlo911 Apr 11, 2004 04:52 AM
2+ years and one of them is a cheap DEPO brand corner light and none have signs of melting or warping.
Jatan Apr 11, 2004 07:14 AM
I'm using regular 1157 Sylvania bulbs and no problems so far (did it last summer). The yellow doesn't go with the white light from the Cool Blue bulbs so I'll replace it soon with hyperwhite bulbs.
z32drifter Apr 11, 2004 08:02 PM
Thanks nismos14........... both cars have been a labor of love :) there is a small wright up on the Z32 at http://members.cardomain.com/z32drifter
nismos14 Apr 11, 2004 08:39 PM
np the slicktops were so rare and nice, i always wished i could find a slicktop black on black mmm that would have been so nice lol i just wish i had kept the z32 tt rims i had on my 240 to put on the max, those would have been beautiful just like ur car
Brudaddy Apr 12, 2004 11:16 AM
I have also read threads about people that have done this and cracked or melted their housings. I would not do it, because it is just making more heat than it was designed for. It cannot handle the heat, the housing will be affected.
Those of you that have not had problems, you are pretty lucky or something.
nismos14 Apr 12, 2004 01:45 PM
there are multiple ways of doing this, if you just turn the bulb around after taking off the nub, i believe it is more likely to be a detriment, if you actually re-wire it then i do believe there is less possibility of burning/melting, i have had no problems at all with my re-wire
acj Apr 12, 2004 02:26 PM
I re-wired mine about 3 months ago after I got the car. and no problems yet!
But if I start to see any signs of melting or burning I'll be sure to change it back...
