Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Car won't start after fuel filter change (https://maxima.org/forums/4th-generation-maxima-1995-1999/232077-car-wont-start-after-fuel-filter-change.html)
Maxin It May 30, 2004 08:26 AM
I depressurized the fuel system before replacing the fuel filter. Now when try to start the car, it won't start. There is no fuel being pushed through the fuel filter. I followed the Haynes manual when replacing the fuel filter and it says nothing about repressurizing the fuel system. Any suggestions? Thanks for your help.
Jatan May 30, 2004 08:46 AM
Did you put the fuel pump fuse back in?
Maxin It May 30, 2004 08:51 AM
Yes... and I don't hear that "whirring" sound when i turn the ignition to ON just before i start the engine
njmaxseltd May 30, 2004 10:43 AM
Check that fuse.....
mrglynis May 30, 2004 10:51 AM
I agree, double check the fuse. Make sure it is in the correct spot. I made that mistake the first time. Also check to make sure the fuse isnt blown.
If that doesnt work.....How many times have you tried to crank it? This is a long shot, but look to see if the security light to the left of the steering column is on solid. It should be flashing. If its on solid, call a tow truck. It would mean your immoblizer system is activated. Its a reach, but it happened to me. You'll have to take it to a dealership to have it reprogrammed.
ManualMaxima May 30, 2004 12:05 PM
the fuse it what happened to me. also try dicconnectign your batter and connecting it again.
Brudaddy Jun 1, 2004 10:40 AM
It should take it a few to get it going. There is no fuel in the lines.
The fuse is probably your problem.
njmodi Jun 1, 2004 10:47 AM
Not to undermine your DIY ability - but are you sure you didn't install the filter upside down... it would definitely still fit...
If you don't hear the whirring its most likely your fuse - I know at least one fuse near the fuel pump fuse is "unused"... double check that you didn't replace the "wrong" fuse.
Maxin It Jun 1, 2004 11:29 AM
Thx for all the replies... yea it was the fuse. I placed it in the wrong "unused" location since there were 2 unused fuse locations near the fuel pump fuse after i pulled it out. Stupid me :slap:
Everything else was fine... and no i didn't install it upside down lol. Now it's back up and runnin :thumbsup:
njmodi Jun 1, 2004 11:32 AM
Glad you got it sorted out... :thumbsup: ... those unused fuses have thrown me off once before too...
Brudaddy Jun 1, 2004 12:31 PM
yeah, I almost did that.
I realized it just it time though.
{-_-} Jun 1, 2004 01:35 PM
glad it went well with you as i'm about to do this myself. i'll remember to put the fuse in the right place afterwards. ;)
