can you suggest Winshield wipers
Yes, Rain X
Originally posted by maxse91
may i suggest just using rain-X and buying whatever wipers you want, it wont matter after you apply that , works incredibly
Try Bosch or Trico
While RainX is pretty good stuff to use to keep your windshields clear, you will eventually need to replace your wiper blades as they don't last forever. If you live in Seattle, you'd probably have to replace them about 2x/year as you use them almost daily 9 months of the year.
As for brands, try the Bosch brand wiper blades (there's 2 versions, both good). They are about $10 for each blade, including the wiping element. You can then buy the wiper replacments when the rubber element gets worn. Both Bosch blades look stock as well.
Trico brand blades (about $8-9/blade) look very OEM as well--they should as they are OEM manufacturers of wiper blades; however, I feel Bosch have an edge in wiping quality.
rainX
I have used BOCSH blades in the past and they worked great for about a month, but it was down hill from there. I recommend that you buy another Pair of Nissan Blades because they out perfrom the competition and last way longer. Just my opinion of course, but I have tried every thing.
Emax: How much were the OEM Nissan wiper blades (including the wiper element)? If they're a few bucks more than the Bosch, I might try them out next time I go about replacing the wiper blades to see how long they'll last to the others, as I've tried a few aftermarket brands. If you're right about the OEM blades, then hats off to you in advance.
Emax: If the Nissan wiper blades are $40/pair--OUCH! I might be sticking w/ the Bosch then! However, since I'm going to be getting an oil change at the dealership on Wednesday, I'll check to see how much they really cost for a pair and if not more than $15/each, I might give them a try as you mentioned they work and last longer than others. While the Bosch are good, I'm willing to see if something else is better. Thanks for the info.
Rain-X
Don't put Rain-X on your windshield. It is just a wax, and eventually your windshield will be worse off than when you first did it. Really, you might as well just wax your windshield. There is a product called Aquapel that has a similar effect, but lasts longer and won't ruin your glass.
Re: Rain-X
Re: Re: Rain-X
just how exactly do you ruin a windsheild?? Ive used rain-x since i can remember and have had nothing but good things to say, you really cannot beat it in the rain for visibility, no wiper can come close
I used to work for a large autoglass company. We would constantly get complaints from customers about Rain-X. You can usually take care of the problem with Bon Ami, but I've heard of extreme cases, usually when it wasn't applied correctly, of having to replace the windshield. Aquapel is not supposed to have the same problems that Rain-X has, and lasts a lot longer. I haven't personally used it, but have talked to a lot of people who have.
Basically, my point is that Rain-X is more trouble than it is worth. I used to use it, but I was told not to by good friends who have been in autoglass for 20+ years. To be honest, they don't use Aquapel either that I know of, but they do recommend it.
Re: Re: Rain-X
Bosch Blades
Get Bosch Micro Edge Excel blades.
You'll need a 21" and a 22" blade.
I haven't had any problems with them breaking down.
They wipe water away perfectly, and I've never had them "chatter" or "squeek", even in cold weather.
I used Rain-X, maybe twice per rainy season in CA. Haven't found any problem yet. But I do see a color difference between where the wiper can sweep and where it can't reach (in the upper right corner). Even after I cleaned the windshield with Windex, inside and outside, I could still see the border line. I'd like to know what I can do to fix that. It is not so bad though.
Re: rainX
That's me. The reason why I bought RainX is because everytime when I use the windshield wipers, it produces an annoying film. I was in my cousin's CR-V and when he used his wipers, it was very clear. So to solve this problem (I thought) I bought the Glass Polish from RainX. I was so glad that it made my glass a little cleaner but now I have scratches from the wipers. Probably this spring break, I'm going to replace the windshield (it recently had a chip from a rock) and not use RainX again. Others have used it and they seem it's fine but I'm probably going to stay away from it from now on.
Originally posted by Matrix
Someone on this board complained that Rain-X ruined his windshield
DC_Juggernaut
09-28-2015 04:07 PM
