Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Any Pointers for installing CV axels? I'd like your experiences... (https://maxima.org/forums/4th-generation-maxima-1995-1999/244465-any-pointers-installing-cv-axels-id-like-your-experiences.html)
eturnl Aug 17, 2004 06:31 PM
I'm about to install new CV axels, and i was wondering is there anything i should know, like avoiding common mistakes? forgetting something. i just want your experiences, i've done this before on other cars, but not on my max.
s0ber Aug 17, 2004 11:14 PM
*bump*
i would like to know this as well.
eturnl Aug 18, 2004 09:36 AM
Anyone have any experiences? In the Chiltons, it says You cant remove the drivers side axle untill you remove the passenger side axle first!? wtf?! on an automatic tranny that is
fishpony Aug 18, 2004 12:13 PM
it's really easy to do with the right tools. i didn't take out the passenger side and i just did the driver side.
s0ber Aug 18, 2004 12:53 PM
How long did it take?
eturnl Aug 18, 2004 01:20 PM
What are the right tools? i dont have air tools this time, im afraid its gonna be a ***** to take off the axle nut!
s0ber Aug 18, 2004 01:25 PM
Think you would just need some elbow grease and a breaker bar
Batxel Aug 18, 2004 01:34 PM
Get a breaker bar and a 6 foot long pipe that will fit around the breaker bar. I was able to get these off mine. Believe it or not my lug nuts were on almost as tight as my axle nut. I would be ****ed if I got a flat tire in the middle of nowhere and took out that little 6 inch thing in my trunk!
:hmmph:
I'd do the passanger side first since its much harder to do. I like to takle my jobs by doing hardest things first and the easiest last.
Remember Torque equals force x distance. The longer the pipe the easier. Use this site for additional help -->http://www.motorvate.ca/mvp.php/805
His car has manual just as mine does so I'm sure how much different an automatic would be.
Yotionblade Aug 19, 2004 12:53 PM
I did this on my 97 max gxe 5 speed a few weeks ago. The passenger side took for ever to get off. The damn thing was rusted in the carrier sleeve. I had to use an air chisel to get it out of the carrier. Other then that its a pretty easy process. On the driver side just make sure you can get a breaker bar or large screwdriver etween the axle and the tranny to pry them apart. Also make sure use a drip pan cause when you pop that axle out all the tranny fluid follows.
