Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Front Rotor's Help (https://maxima.org/forums/4th-generation-maxima-1995-1999/245348-front-rotors-help.html)
killcrap Aug 21, 2004 06:05 AM
Front Rotor's Help
Hey whats up, i just replaced my front brakes with Raybestos QS, and is the rotor supposed to be loose when i take off the wheel? its got some slack in it, but it becomes tight after i put the lugs back on. oh and another question. i pushed in the piston to put the caliper back on the pads, and my brake fluid is almost topped off. if i push in the brake pedal will this fix it, and return back to normal level? thanks!
passEMonTHErite Aug 21, 2004 06:14 AM
#1. As long as its tight when you put the wheel back on you should be okay.
#2. Absolutely.
killcrap Aug 21, 2004 06:20 AM
thanks man. appreciate it
datguyclark Aug 21, 2004 09:23 AM
**the rotor is completely normal...did u crack the bleeders when u compressed the pistons in the calip[er
