Question about ECU's 95-99
Question about ECU (computer ) on 1997 gxe 5speed...
Or question really is I have a 1997 gxe 5 speed what years can I replace with??? Is it only 97-99??? or does it have to be strictly a 97 5 speed. Also why does it matter 5Speed or Automatic ECU (computer). They installed a automatic ECU and its making my revs bouncy still runs but shaky and bouncy??? Thanks... |
direct question
directly can I use a 1995 ECU 5speed stock in a 1997 5speed will it be compatible....that is simply my intentions will it work or not???????
thanks... |
yes but with a possible CEL. I have a 95 ECU working in my 98.
you can also use a 96 ecu in your car
You can use any 95-98 ECU in any 95-98 maxima. Some will get SES lights while others won't but they will all run. Only 95-96's can be reprogrammed at this time, so 97-98 ppl need to buy a 95-96 ECU to be reflashed by TS or JWT. I believe some 99s with some wires swapped can also use the 95-96 ECU as well.
I know you can install an auto ecu in a manual car and you may have some extra codes, but I am not sure about installing a manual ecu in a auto car. There is a much larger supply of auto ecus anyway. |
Quote:
i have been trying the 96 ecu in a 99 and im not having any luck. even with the wires swapped. |
Yeah I was not sure about that one. I think the 99.5's may have a 5th gen ecu maybe. I am not really sure. I just remember that someone saying that with a few wires that at least SOME of the 99s could use a 95/96 ecu. Maybe once TS comes out with 00-01 ECU you may be in luck. I will search around for the thread talking about the wires to swap. I think JWT may be able to work around the 99 differences as well and make it work. Call JWT, they may know more.
http://forums.maxima.org/showthread....&highlight=ecu
http://maximaracing.org/viewtopic.php?t=1017 JWT supposedly can get a 95-96 ECU to work with a 99. |
JWT would have an answer for you, I 2nd that from h2kSPiG
i have called jwt and they are not sure but they thought it was the fuel pump pin also. im working with a enginerr for nissan and he is going to see what has to be done for it to run in the 99...
How did you fry your first ECU??????????
I have posted this in many threads, Chuckie, Have you dissconnected the immobilizer yet?
if the question is to me...
Quote:
Be aware of the Service Bullentin it happened to my 97 the water backed up in the A/c tube and water started coming inside and wet the ECU and it went crazy till it didnt start the car anymore. Their is bullentin that the underneath the wipers leaves & dirt gets caught in there and clogs up where the condensation came inside the car. Sucks bigtime.... |
Quote:
i have post this many times the immobilizer has nothing to do with it in the 96 ecu . even jim wolf said so also |
Yes, but you have said the security light stays on when you are turning on hte car which means the immobilizer system is activated, it wouldn;t hurt to try and dissconnect it.
I appreciate all the help
thanks |
I have unplugged the gray connector on the ECU. do you folks know how to pop off the white plastic box? i need to open it.
http://memimage.cardomain.net/member...68_20_full.jpg |
| All times are GMT -7. The time now is 02:24 PM. |
