Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   how come my horn isn't working? (https://maxima.org/forums/4th-generation-maxima-1995-1999/252386-how-come-my-horn-isnt-working.html)
rwatt1981 Sep 23, 2004 09:49 PM
i took off the steering wheel and airbag to dye my dashboard and replace my steering wheel black...i got all the connections right and clockspring turned back to where it goes, however, my horn isn't working? the fuses are good,,,except for the one on the passenger-side under the hood,,,i couldn't remove it somehow, just gave up. any suggestions on where to look for the problem? my inspection ran out and i need my horn to work in order to get it inspected....thanks!
liqidvenom Sep 23, 2004 10:01 PM
cause the chicken isnt making noise.....
ogparjay Sep 24, 2004 12:40 AM
you don't need it don't worry. if you think that a certain something is causing the problem then it might just be.
mendon11 Sep 24, 2004 07:38 AM
you are probably out of horn fluid. you can pick some up at your local automotive store
MaxedOutOfCash Sep 24, 2004 10:54 AM
I'm lost.............
