Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Help!! Car doesn't always start!! (https://maxima.org/forums/4th-generation-maxima-1995-1999/253992-help-car-doesnt-always-start.html)
chimpigin Oct 1, 2004 05:04 PM
Okay guys here's my problem. About 2 weeks ago, out of nowhere I got in my max and it wouldn't start. You can here the engine cranking like its about to start, but it just wouldn't turn over. Somehow I got the car started by flooring on the gas.
I drove the car the next two days w/no problems. I get into my car on a Tuesday morning to go to work, and the damn thing wouldnt start again!!! So i get home from work and it started fine!?!?!
I brought the car to my mechanic on Wednesday and he hooked it up to his machine.(I forgot to mention when the car eventually started the first time the problem existed, the Service Engine Soon light finally came on (I got about 81K on my max)) He told me he didn't find that there's anything wrong w/the car (since it started for him) after the diagnostic except for 2 sensors. He said he realigned the sensors, but didn't replace them.
The car started fine for 2 weeks, and then bam yesterday it wouldn't start. I tried today and it did.....
What the heck is wrong w/my car? Can bad sensors cause your car to not start at times? I'm ruling out the alternator since I got a new one due to the recall around 66k. I'm sure its not the starter since it does start most of the time.
What could the problem be? Maybe bad ignition coil or a bad fuel pump?? Please help!!
Blue96Max Oct 1, 2004 05:13 PM
Spray Sum GUMOUT Carb+ Choke Cleaner to both ends of the choke valve shaft while working choke by hand. Spray down and around the carburetor throat to remove deposits from the throttle plate area.(Your Injecters Are Maybe Dirty)
chimpigin Oct 2, 2004 06:56 PM
I brought my car into nissan today and they ran a diagnotic, and it didn't throw any bad codes. The guy called me up and said my electrical system is bad. Something about how there's a bulletin on it (and of course my warranty is up) and that the whole elecrical wiring harnesses have to be changed and its going to cost $2300!!! Does this sound right??
chimpigin Oct 3, 2004 05:50 PM
somebody please advise!!
f550maranello2 Oct 3, 2004 06:01 PM
no thats probably not right thats what happens when u take the car to the stealer, the starting or lack of can be contributed to many things as u will read on this forum lots of people are having the same problem not too many people have figured it out yet so keep lookin. sorry that i cant give u any more advice but i have dont everything that i can think of to correct the problem and still does the same thing.
cam_honestiam Oct 5, 2004 04:53 PM
Avoid the Dealership at all costs. I have been told several times that things were wrong that really weren't, and with patience and persistence, I have been able to fix most problems myself. Investigate a bit further, get your hands dirty; learn how stuff works. Ask the mechanic dude which sensors he "aligned", what they do, and why he did what he did. RESEARCH
