Post pics of your bbk and wheels
hey just wanted to get an idea of what other setups look like. please list if you have any type of spacer needed and also the offset of your wheels. post any type of bbk. ap racing, brembo, wilwood, blemco, cobra rotor/z32 caliper.
thanks |
bump......i know there are ppl on here with bbk.
I have some pics on my cardomain homepage of both my stock caliper and 13" rotor and z32 caliper and 13" rotor, both installed and just mocked up using a wooden bracket. They aren't as cool as some people's brakes though like slammed95's for instance. His brakes are awesome.
I definately needed a spacer to make the z32 caliper fit under the high offset kosei K1, I needed like 14mm (so I used a 15mm spacer). With the stock caliper no spacer is needed though even though the cobra rotor causes the caliper to sit slightly outboad of it's normal placement. |
Originally Posted by sagamax
thanks for your help what was the original offset of your wheels.
i found it on your cardomain never mind
my wheels are 42mm offset. i purchased the 15mm spacer hopefully that should do the trick with out my wheels sticking out too much
Z32 fronts w/ cobra rotors
http://memimage.cardomain.net/member...84_32_full.jpg http://memimage.cardomain.net/member...84_49_full.jpg |
thanks guys :thumbsup: any more pics ppl
Yes I sell the brackets that allow the use of these 13" rotors.
http://www.digitalbeta.net/jeff92se/photos/IMG_5477.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
