Right Head light keeps going out!
Heres the problem:
The Head light seems to be loose, when it goes out all I have to do is move it from the back of the headlight and it starts working again. If I turn off the car, and then back on it stops working again and I have to do move it from the back so that it works again. Whats the problem???? |
Bad bulb or the plug is faulty.
Everytime it goes off I move the plug and comes back on. But why does it only stop working only when I turn off the car. In other words I can drive around all day and it wont go out.
Do you have aftermarket bulbs in? If you do the plug is probably melted and you should replace it. That happened to me, I just picked up a harness at AutoZone for about $6, spliced the wires, connected it and its as good as new. I did both and I havent had a problem since.
definetly a bad harnes replace it
© 2024 MH Sub I, LLC dba Internet Brands
