Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Serious problem with my car, won't start, please help! (https://maxima.org/forums/4th-generation-maxima-1995-1999/261949-serious-problem-my-car-wont-start-please-help.html)
WillMax95 Nov 7, 2004 02:31 PM
I went to turn on my car today and it wouldn't start. Everything would turn on (the radio, subwoofer, lights, etc), but the engine wouldnt start, it wouldnt even crank. I'm not sure why its doing this, but does anyone have any ideas or know why?
njmaxseltd Nov 7, 2004 02:41 PM
Starter? - common problem
Ignition switch? - seen a few go bad on here
Battery? - naaa because your accessories work
gto400no1 Nov 7, 2004 02:47 PM
im thinking its a starter. have you gone through a large puddle lately?
joe k Nov 8, 2004 06:07 PM
WillMax95, I am having the same problem on my 95. I took it to the dealer twice and they can't fix it. I read on www.samscars.com/mage9.html about an intremittent Nissan. It sounds like the problem is corrosion on the positive battery cable, not on the main cable that goes to the starter, but look for corrosion under the red colored plastic cover that goes over the two smaller wires that go to the starter soleniod. That is why your car still has power, but will not crank over. If that link does not work, just go to www.samscars.com and lokk for the intermittent Nissan article.
Saddles Nov 8, 2004 07:51 PM
i have that....its my ignition which....nice little anti theft device...only 3 people can start my car, me, my friend who had max, and the guy he sold his max to
maxs4life Nov 8, 2004 10:47 PM
i have the same problem now
i feel bad for u because u will have a hard time with this
like me i chage almost everthing and nothing. i havent had my car for 3 weeks and this s**t is getting stressfull. i ve change everything.
you please keep me posted with your car
good luck :help: :support:
NyCzBuBBa Nov 8, 2004 11:04 PM
Ok well my two cents are if either it's your starter(most likely) Or your battery connectors they are corroded. I heard you can take warm water and baking soda to clean them off. Then reconnect to the battery tightly.
