Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Symptoms of bad coils? here's what i have (https://maxima.org/forums/4th-generation-maxima-1995-1999/268776-symptoms-bad-coils-heres-what-i-have.html)
viktornguyen Dec 9, 2004 11:37 AM
1998 max... bosch +4 plat plugs for past 6k miles.
New ECTS, fuel filter, mobile 1 syn, used chevron techron injector cleaner, cleaned throttle body,
Car is stalling alot at lights and stop signs. RPMs very inconsistent. Acceleration studders alot and is very jerky.
Sound like coil problem???
My guesses so far: TPS sensor, knock sensor, maybe wrong spark plug types, IACV, fuel pump, .... should i add coils too???
sterlingmaxima Dec 9, 2004 11:41 AM
get rid of those boshes you obviously never read teh stickies stick to ngk bro
MaximaSE96 Dec 9, 2004 12:04 PM
try NGKs first if problem persists then yes i would ay coils.....BOSCH BLOW
ManualMaxima Dec 9, 2004 06:37 PM
yes accelorating studdering is a problem associcated with coils. I just experianced this and it was 1 of my coils that were messed up. try testing your coils. and pm with which oine and i might have an extra one laying around.
NyCzBuBBa Dec 9, 2004 07:28 PM
how do u test the coil packs?
TheMax95 Dec 9, 2004 07:30 PM
bump I want to know too.
-Paul
killcrap Dec 9, 2004 07:39 PM
if your rpms are jumping around, then most likely its going to be something in your ignition or fuel delievey. what codes are you getting?
Maxine Dec 9, 2004 07:59 PM
I thought mine problem was with the coils to but it turned out to be a injector on cylinder of course under the im. So i replaced myself and saved $300+dollars. So dont rule out your fuel injectors.
viktornguyen Dec 11, 2004 07:16 AM
SH*T so how do u go about testing the injectors and coils???? I tried chevron techron to clean injectors.
Car starting to stall alot more now. i need to get this resolved ASAP!!!
Called nissan dealer that they said $79 bucks for diagnostic.
NyCzBuBBa Dec 11, 2004 07:18 AM
try changing ur MAF
I30tMikeD Dec 11, 2004 07:22 AM
1. It's not the knock sensor
2. Try changing to NGK coppers or plats. Cheapest possible fix
3. CEL? Any codes?
4. I doubt it is a fuel pump or IACV
5. My guess would be coils, MAF, or the plugs
6. I would try unplugging one coil at a time while the car idles. If the car starts to run worse then it's not that coil. If when a coil is unplugged and no change occurs then you have found your problem. Free, easy way to do some diagnostic.
viktornguyen Dec 11, 2004 07:32 AM
SH*T!!!! so how do u go about testing the injectors and coils???? I tried chevron techron to clean injectors.
viktornguyen Dec 11, 2004 07:33 AM
OOPS!! my bad for repost.
I30tMikeD Dec 11, 2004 08:06 AM
:rotz: Go buy a haynes manual from any autoparts store, or maybe try what I posted above
viktornguyen Dec 11, 2004 08:11 AM
Got some SES codes:
01-long 02-short - Mass Air Flow Sensor
05-long 12-short - None Existent in ECU decoder ... wtf is this?
The MAF would cause the big stalling problem??? how much are we looking at?
viktornguyen Dec 11, 2004 09:08 AM
I think i probably have bad coils though on top of other problems i may be having... not sure if coils could cause any CEL codes, but it feels like the car is running on 5 cyl instead of 6 half the time. The way the engine is reacting feels like something isn't igniting right..
Is there 1 type of coil or several?
From: http://www.nissanparts.cc/catalog/?section=438
I got the following prices for them. Prices are reasonable.
I think there's 1 for Left Side and 1 for Right hand. Should I just go for 1 of each to be safe??
Quantity Part # Description List Unit Price Price
1 22448-31U11 Coil Assy - Ign $78.51 $59.83 $59.83
1 22448-31U06 Coil Assy-ignit $71.92 $54.80 $54.80
1 22448-31U01 Coil Assy-ignit $75.38 $57.44 $57.44
1 22448-31U16 Coil Assy-ignit $75.36 $57.43 $57.43
Subtotal: $229.50
Excuse the newbishnish: Coils are the things that go on top of the Spark plugs right?
TonyGotSkilz Dec 11, 2004 09:15 AM
Theres two types, front bank and rear bank, and yeah the coils go on top of the spark plugs... If your not getting a Cel though (which would tell u what coil it was) then i don't know if you should bother getting a coil at all... i did and it didn't help so it looks like i wasted my money... first make sure u know what the problem is.
I30tMikeD Dec 11, 2004 08:53 PM
Subtotal: $229.50
Dude, you did not get a misfire code that would indicate a spark problem. You got a MAF sensor code. That is what you need to be looking at.
anarchy57 Dec 11, 2004 09:26 PM
im in the same position aswell, i wish the CEL came on so i know wtf is wrong! my CEL did come on the other day tho, it was blinking then it stopped...
NyCzBuBBa Dec 12, 2004 01:11 AM
MAFFFFFFFFFFFFFFFFFFFFF causes stalling........I just changed mine feels like a brand new car. What happens is the sensor of the maf is reading bad air/fuel so causes ur car to run bad. Just the short version if someone wants to EXPLAIN totally go right ahead but that just ur basic problem. Change the MAF and you won't stall.
dsn111 Dec 12, 2004 04:07 PM
Not about stalling...........just doesnt acccelerate cleanly (jumps a bunch when pushing the gas pedal hard) and then on top of that sometimes when the car is stopped at a light and just idling, the engine also feels like it jumps sometimes (slight jerk, or lose of power feeling)......
any more suggestions?
ds03 Dec 12, 2004 05:38 PM
It's a coil problem. Had this happen recently to my 99 and also in the past with my 91. Like was said above, the easiest way to check it just disconnect each plug one at a time and see if one doesn't make a difference (that's the cylinder w/ the bad coil).
viktornguyen Dec 13, 2004 10:46 AM
Great news guys, put in a new MAF today and car is running like a champ.
Also unplugged my coils one by one and car reacts to each one so i think all my coils are good. Also put in copper NGKs.
But all in all changin the MAF did it. Bought a used one from junk yard for $75 bucks... Dealer woulda charge 400+ i think for one of these.
Thanks for all you help guys.
