Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   New Brake Break in. I'm concerned.. (https://maxima.org/forums/4th-generation-maxima-1995-1999/274621-new-brake-break-im-concerned.html)
FormorAccordMan Jan 7, 2005 03:17 PM
just had the new rotors and pads put on today. My shaking has ceased. :woot: Car is now smooth as a Max should be. The only thing is- Now with the new brakes under hard braking they groan- sometimes quite louldy actually. I brought it back and they told me that it was because the pads and rotors are brand new that there is a coating thats needs to wear away and that was causing the groaning. It sounds like a loud HHMMMMM, you can also feel it through the pedal. The car stops much better and is much smoother, no more grab-release-grab release feeling when coming to a stop light- I can actually ride the brake again. But the groaning concerns me. Is this normal? I dont want to damage these brakes. Thanks
|Bijan| Jan 7, 2005 03:48 PM
Sounds like the parts werent cleaned before they were installed.
Ant96GLE Jan 7, 2005 03:50 PM
My old brake pads would moan and grind under very hard braking... but other than that they never squealed or did anything out of the ordinary. I dunno why, I'm guessing its because of the pad material :confused:
I'd like to know why it would do that as well
Right now I'm on another set of pads and new rotors... smoooooooth as can be
FormorAccordMan Jan 7, 2005 03:51 PM
I saw them spray the hell outa the rotors
Ant96GLE Jan 7, 2005 03:53 PM
I think he means clean the hardware.. ie shims and pins that the pads rest on
FormorAccordMan Jan 7, 2005 04:28 PM
I just went back to the place but the guy was gone for the night- now i have to go BACK again tomorrow. Also, when I pulled in, I could smell the new brakes. :nervous:
Ant96GLE Jan 7, 2005 04:30 PM
The smell is normal... after I put my new ones on I could still smell them for a day or 2 later after hard braking
kraimer21 Jan 7, 2005 04:44 PM
its so weird to see this thread because i just put in my new pads (oem) front and rear about 2 hours ago... i did the required procedure for breaking in new pads...still whenever i press the brake pedal, there is a really weird grinding noise, at first i thought, all right its probably cuz they are new but i drove for a while and it hasnt gone away...my friend told me it took him almost a week to get rid of that noise so we'll see..
so im sure you have the same thing, just give it some time
VIP Maxima Jan 7, 2005 05:23 PM
hha good luck with that one. been dealin with grinding feeling and noise every since i put on my NEW pads and rotors and it will never go away. guess what, u should never put new pads and new rotors on. 1 at a time to brake them in properly. sorry to burst ur bubble but im being for real
FormorAccordMan Jan 7, 2005 05:38 PM
Then what about brand new cars? Arent both the rotor and pad brand new? I don't understand.
Ant96GLE Jan 7, 2005 06:16 PM
You have no idea what your talking about do you? :laugh: :p
if true like said above... what about new cars? :confused:
apbrian112 Jan 7, 2005 06:30 PM
^^^ actually i've heard the same. that when possible you should try to put new rotors on with the old pads (or vice versa). something to do with the wear characteristics and prolonging the life of both.
VIP Maxima Jan 7, 2005 08:17 PM
im just tellin him what the .org has concluded for ME.
how do u know that in factories, the rotors arent pre broken in before put on the car and only the pads r completly new?
ScarfaceTHX Jan 7, 2005 08:29 PM
On a similar note. I just got my brakes turned with new rotors.
DUST EVERYWHERE
I have to wash my car every week. This is highly unusual for me because I never freakin wash my car because I hate doing it. Oh well. If it does it for much longer I will just have black front rims. f it
adithius Jan 7, 2005 10:49 PM
New rotors come with a thin layer of grease that should be cleaned with alcohol. But if they are not cleaned this will go away.
The groaning sound is most likey due to over greasing the caliper pins. When over greased, the pins dont allow the pads to release from the rotors. The pads stick to the rotors causing a groaning sound. Have the brake shop get the old grease out and put in the proper amount of grease. I'd also recommend you have them put anti-squeal so the pads dont squeal. This is just grease they put on the back of the pads.
As far as breaking in brakes, it takes a good 500 miles. But the first thing you should do is drive to 40MPH and slow down moderately -5mph. Drive around for a half hour.
Nismotic Jan 7, 2005 10:51 PM
I had my set of OEM brakes put on and they moaned for a week or so...
adithius Jan 7, 2005 10:52 PM
DUST EVERYWHERE
If you changed your rotors w/o changing pads, the pads need time to adjust to the new rotors. This is why you are getting so much dust.
It's recommended to change the pads. If you did change the pads too, I'd advise to get better brake pads next time.
adithius Jan 7, 2005 10:56 PM
:smash: :smash: :ban2: :ban2:
Would you just listen to yourself?
Frank Fontaine Jan 8, 2005 05:59 AM
hmmm...I've had great luck with the OEM, never a groan (are we talking originally about a squeal or a groan, as they are diff.--if I understand it, the groan is due to the pads, the squeal is due to the rotors, the squeal being the high pitched sound). On the front, I totally forgot to put the shims back in and did not use the kit that I had purchased. Still, no groan. So there is something about the OEM pad and the OEM rotor, just work well together. I've got 101k and the rotors are original, never been turned, no pulsation at all.
I can't really say, but I'm going to guess the poster's groan will not go away--they may have installed economical pads which are supposedly tough on the rotors, and/or maybe there are no shims in there which would be the next step in eliminating that type of noise. Anyway, in theory, something has to change with the force being applied. All things being equal, to me that would mean the installation of shims, or installing a pad with a different composition. Again, that's theory--maybe it does go away with wear, but I doubt it.
All the comments about replacing the rotors to me would only make sense in the case of a high-pitched squeal. If it is in fact a low-pitched groan, replacing rotors would be like throwing out the baby with the bath water.... :Popcorn:
vahmed Jan 8, 2005 07:18 AM
I had changed both the rotors(oem) and the pads at the same time back in Nov. no problems so far I don't know if it makes any diffrence since I put ceramic pads.
