Are wheel bearing issues common on 4th gens?
Old 02-21-2005, 08:09 PM
Nathan's Avatar
I've just recently been looking at buying a '97 SE and I have since found one that I might buy. I went for a test drive today and everything seemed good, except for a strange noise coming from the drivers side front wheel well. The sound was only noticeable at speeds over 10km/h and would get louder as I went faster, but not loud enough for you to hear with the radio on. It was like a constant whoosing sound.
I suspect that it might be a bad wheel bearing. How common is this on a 4th gen's and has anyone had to replace theirs? I'm going to get the car inspected by my mechanic, but I thought I'd get some suggestions first. The car has 100,000 miles on it.
Nathan is offline
Old 02-22-2005, 06:09 PM
Stuntin' 101's Avatar
i had them done on my 95 more than once.. the 96 i have now, i had to do the rears..
Stuntin' 101 is offline
Old 02-22-2005, 07:10 PM
matty's Avatar
96' with 134K on original bearings....I may put new ones in when I do my brakes...we'll see
-matt
matty is offline
Old 02-22-2005, 07:27 PM
U wanna try me young boy?
Scruit's Avatar
I haved 120k on my '96 and my bearings are fine.
Scruit is offline
Old 02-23-2005, 05:41 PM
Nathan's Avatar
Thanks for the help guys!
Nathan is offline
Old 02-23-2005, 06:04 PM
big_al's Avatar
I have that noise too. I took in in and the guy said the bearings are fine. wierd.
big_al is offline
Old 02-23-2005, 06:24 PM
Ant96GLE's Avatar
As far as seeing threads about people having problems with them... its not a common problem.
Ant96GLE is offline
Old 02-23-2005, 07:30 PM
Maxima Owner
MaximaSE96's Avatar
my 96 had 193k on originals
MaximaSE96 is offline
Old 02-23-2005, 08:33 PM
Hatteras's Avatar
I have a '95 Maxima & had to replace my driver's side front 2 months ago at 185,000 miles. I bought it with 111,000 miles on it, so I'm not sure if had ever been replaced.
Hatteras is offline
Old 02-24-2005, 05:51 AM
knight71's Avatar
Sometimes it's not the bearings at all, a worn or defective tire could simulate the same noise as a worn bearing.
knight71 is offline
Old 02-24-2005, 07:08 AM
adithius's Avatar
How can you tell that you have a bad bearing?
I had my front left changed. The mechanic at Pep Boys showed me that my rotor moves side to side while the calipers were on. I dont know if he was right or if he wanted to charge me more money, while he was changing the CV.
How much are bearings anyway?
adithius is offline
Old 02-24-2005, 08:58 AM
Viscous's Avatar
I had to replace my pass side front bearing not too long ago, 118k miles. It was making a really noticeable hum at speeds over 10mph.
It should cost around $200-$300 if you get someone to do it for you.
Viscous is offline
Old 02-24-2005, 09:00 AM
ronin22357's Avatar
i had to replace my pass. front at around 80,000 or so miles
ronin22357 is offline
Old 02-24-2005, 09:10 AM
1FSTMAX's Avatar
mine lasted about 149k or so...
1FSTMAX is offline
Old 02-24-2005, 01:52 PM
blueice's Avatar
Where is the cheapest place to buy them? I think my right rear one is dead it sounds like bad tire noise when I make left turns, but the alignment was just done and the tires are fine.
blueice is offline
Old 02-24-2005, 02:01 PM
Maxima 504's Avatar
Ever since I replaced my tires and my tire "hum" went away from the rear, I began to notice this slight groaning noise on my rear left side.. I wonder if this could be a bearign making this noise or maybe the rear claiper sticking..
the weird this is that it only happens on right turns.
Maxima 504 is offline
Old 02-24-2005, 02:04 PM
Maxima 504's Avatar
Sorry to hijack the thread but what else besides a bearing issue can cause this type of noise in the rear.. since there are no axles and it only happens on a right turn?? Thanks in advance.
Old 02-24-2005, 02:05 PM
Custom User Title
Nismo3112's Avatar
179k on original bearings
Nismo3112 is offline
Old 02-25-2005, 11:58 AM
blueice's Avatar
Where is the cheapest place to get them?
blueice is offline
Old 02-25-2005, 12:37 PM
Needs non-Maxima Friends
nismo2020's Avatar
Both mine went out @ less than 100,000 miles. makes an awful sound
nismo2020 is offline
Old 02-25-2005, 12:41 PM
alpicone's Avatar
I think the humming noise that most people diagnose as bad bearings are actually noise from the tires. I had a humming noise from my left front wheel. When I changed the tires it went away. 133K on original bearings.
alpicone is offline
Old 02-25-2005, 02:09 PM
1FSTMAX's Avatar
i got mine at my local nissan dealer..
1FSTMAX is offline
Old 02-25-2005, 02:18 PM
EZEMaxima's Avatar
Where the lugnuts on, if not then they are pulling your legs.
EZEMaxima is offline
Old 02-25-2005, 02:53 PM
MaximA VlaD's Avatar
on my 95 se had the hum hum hum noise from the front, esp when curving right. had both bearing hubs replaced when had tranny rebuilt. on that model coulndt press them out. noise went away
now 97 se, same noise, more noticeable, and does it all the time except when curving right. about to replace brngs, got them at Medallion auto center for $40 a side (front)
MaximA VlaD is offline
Old 02-26-2005, 11:56 AM
blueice's Avatar
Do the rear wheels have bearings? Or just the fronts on the maxima?
blueice is offline
Old 02-26-2005, 02:31 PM
michaelnyden's Avatar
135K on original bearings...no noise at all...
michaelnyden is offline
Old 02-26-2005, 03:01 PM
S Cranaw's Avatar
yah defiantely sound like wheel bearings. Had the same horrible sound, and did the same as you... just turned up the radio so my ears wouldn't pop. I paid $638 to have both left and right changed. That price also included a new knock sensor installed and an oil change. The parts are not all that expensive, its just the long labor hours to have them installed. If it has 100,000+ probably needs to be changed. My mechanic suggested I change the rears soon also. This is going to run me about $320 installed both sides.
-Steve
S Cranaw is offline
Old 02-28-2005, 09:37 AM
blueice's Avatar
So there are no wheel bearings on the back wheels? If not, what in the back axle could be making this type of noise besides the tire or alignment?
blueice is offline
Old 02-28-2005, 12:49 PM
S Cranaw's Avatar
Yes there are rear wheel bearings. Unfortuanatley I need to get mine changed. Could be source of your sound.
S Cranaw is offline
Finkle
09-27-2015 09:53 PM
homeyclaus
09-03-2015 06:15 PM
Flores94
08-11-2015 12:53 PM
FanaticMadMax
08-10-2015 08:55 PM
Quick Reply: Are wheel bearing issues common on 4th gens?
