Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Help....`95 won't start! (https://maxima.org/forums/4th-generation-maxima-1995-1999/288882-help-95-wont-start.html)
maxi-freak Mar 9, 2005 06:27 PM
Flashers start flashing for no reason and then the car won't even try to crank over. Someone suggested a security condition. Even after getting the flashers to stop, it still isn't cranking over. Battery voltage is good.
big_al Mar 9, 2005 07:15 PM
Did you try pulling the negative batt. cable off to try and reset things...???
maxi-freak Mar 9, 2005 07:33 PM
yes...but to no avail.
2 Da Max Mar 9, 2005 08:00 PM
flashers? is your starter ok?
Hatteras Mar 9, 2005 08:35 PM
A lot of 95-96 Maximas are bad for the ignition switch going bad. When it happens, it happens pretty much all-at-once & it makes you think it's something with the security (no starter noise/battery click at all). If you've felt just the slightest looseness in the ignition key recently, I'd bet that's what it is.
maxi-freak Mar 10, 2005 04:40 AM
You know....after thinking about it for a while...I think that there's an aftermarket security system in it. I just bought the car a couple of weeks ago for my daughter. Everything was fine with it for the first week until I wired an amp to her head unit. I also remember an alarm/horn until the hood that the previous owner apparantley snipped the wiring on. All that to say, I suspect that the vehicle is in theft deterrant mode and there's probably something goofy behind the dash that is opening a relay that passes the ignition switch output to the solenoid switch.
My daughter's boyfriend said that he saw some cut and spliced wiring behind the radio cluster when I was wiring in a new head unit yesterday.
I meant when "he" was wiring the new head unit.
maxi-freak Mar 10, 2005 06:04 PM
Ok..problem solved! There was a faulty aftermarket motion sensor that was killing ignition switch 12V from the solenoid switch. It also was causing the flashers to flash. After unwiring it, normal operation returned.
