Battery drain and horn won't stop
I have a 95 max and here's the prob...
The horn has been going off by it self and won't stop. This has been intermittant for a couple of months now. It got to a point where I just unplugged it. However now it has developed a drain. With the cold upstate NY weather and the short somewhere, the battery is usually dead by daylight. For reference I have a Optima bluetop that has been in there for about 10 months. Should I start with the horn and how should i track down this gremlin... |
Have you tried a new battery? Checked all your ground connections? Also, when did you start having battery problems? Is your battery sitting properly on a niece piece of plastic? Do you have it tied down? When you said you unplugged your horn, how did you do that?
No i haven't tried a new battery, the optima is still farely new.
I have checked the connections into the posts of the battery. I started to have these problems about 3-4 months ago. The battery is sitting on the OEM plastic tray. I do not have the battery tied down. And I unplugged the wire going into the horn located directly behind the grill, the horn in the engine bay does not seem to work. |
| All times are GMT -7. The time now is 07:45 AM. |
