Bought a FSB. Doesn't Fit. Help.
I got this FSB off ebay but when I went to install it the bar was hitting some cables near the throttle cables and well as laying on the throttle cables. Has anyone buy the same bar if so, is this normal fir the FSB to lay on top the throttle cables? thanks..
http://images.andale.com/f2/109/113/...9_SBF_NM95.jpg |
turn it the other way around.. then try
def. not ment to rest on throttle cables :slap: |
Tried that, didnt fit correct(Holes didnt line up). I emailed the guys and he said he mailed the right one. So i dunno.
Can some of you post picts of how your FSB looks installed. Mainly picts of where it bolts on and the middle of the bar. Thanks.
is it upside down? people have made htis mistake before for some reason?
Thanks for the picts. And your bar fit with no problems?
And i know for sure i'm not tring to install it upside down. If it doesn't fitthis time, i'll take some photos to show you guys what i'm taking about about when i say its hitting some cables. |
Mine fit. It did touch the hoses as you can see in the pictures. And also on the right side of the car the mount is hitting a metal pipe. Other than that it's fine. I've had no problems with it.
| All times are GMT -7. The time now is 10:04 AM. |
