Programmin remote..Need Help
Can't seem to find info on how to programe nissan remote. Can anyone send me a write-up? Thanx.
get in car
lock door insert and remove key from ignition 6-15 times, until you see the harzards flash put the key in and turn to on ( do not start ) press the lock button on your keyless fob. (hazards should flash again) now you know its programmed. take out key, unlock and open door. test it out. |
Thanx for the info Mdeezy. Its all coming back to me now. I remember having to do that same process on a Nissan Quest at the dealer I used to work at.
no prob :doublethu
more detailed...
Enter the identity (ID) code manually when: * remote controller or multi-remote control unit LCU05 is replaced. * an additional remote controller is activated. ID Code Entry Procedure To enter the ID code, follow this procedure. Entering "Setting mode": (1) Close and lock all doors. (2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated. ID code entry: (3) Turn ignition key to "ACC" position. (4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.) Additional ID code entry (5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock knob. (6) Push lock button on the additional new remote controller once. (7) This ID code entry enable state and setting mode remain until the driver's door is opened. NOTE * If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller. * If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored. * Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored. Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode. |
© 2024 MH Sub I, LLC dba Internet Brands
