mevi intake?
#42
Originally Posted by sdoherty_tjm
yeah and its going to take the guy 15 minutes to put it on after going to autozone when he does not know what it is. then how isnt a turbo? you buy a turbo kit and what you need is there.
o.O
#43
turbo isnt a bolt on because it didnt come from the facotry turbo. the MEVI (Middle Eastern variable intake) came from the factory on Maximas, hence why its a bolt on.
If you have to ask why turbos arent a bolt on for our cars you have a lot more reading to do.
#45
of course not. but if you dont about either, its equally confusing.
/whoring
#46
did the mevi come on my maxima or yours, no it did not. so how is it a bolt on? your not replacing a mevi that was already there with one that is more effective. i.e y-pipe.
and why put a mevi on, its good for how much hp na? somewhere around 5? if you had a turbo it would be more.
#47
a bolt on is a part that does not need fabrication of any additional part in order to get it to work. Just because in the US it didnt come factory on the cars doesnt mean its not a bolt on.
hence bolt on. . . you just bolt it on. . with bolts and done, no fabrication.
#48
If it came on my maxima, or YOURS... WHY would we be trying to put on something thats already there?
How is it not a bolt on? You remove your IM, and bolt on the MEVI? Theres no fabrication to be done like teh 00VI and or a TURBO kit.
#49
I thought you welded it on?
Originally Posted by s0ber
Obviously you know nothing about any sort of VI and its benefits.
#53
why research what you dont think is necessary?
You're right, it ISNT necessary, your car will run without it.. is a turbo necessary? or do you live your life a 1/4 mi at a time?
#56
BTW, I get about 35-40whp more over stock USIM after 5500rpm w/ my 00VI, UNTUNED running rich.. Also the curve is higher throughout the entire rpm band, this comparing to another car w/ same mods without VI.
Hot damn I need to do my 00VI
#60
BTW, where's the friendly, neighborhood PERMA-BAN when you need it most?
#61
Originally Posted by BigLou93SE
Do you only have the manifold, or did you swap the fuel rail and all else too?
#63
And then what? How could you advise to get a "turbo", when you know nothing about the mevi or turbos? Blind leading the blinder
sober didnt say anything about dsm turbo. i said get a turbo. you should go re-read it. jeff guy said that
#64
Ray Charles leading Stevie Wonder into an intersection ...
A cat-less y-pipe didn't come on your car either, but you still consider it a bolt on?
Let's see, some of us don't have the $$ for a turbo, so we do what we can N/A ... and still gain ~40whp @ stock fuel cut
#70
Wow brudda, you've by far made THE worst impression on the .org for as long as I've been on. Well, maybe Tommy Ali had you beat, but you're pretty close.
tommy ali that dumb *** hole.....only took him 3 months to give me my ****
litch
123
01-04-2024 07:01 PM
maxima297
09-30-2015 03:32 PM
