Does anyone else's Check engine light go on and off?
Old Aug 17, 2005 | 05:14 PM
gtmuggs's Avatar
My check engine light goes off and on but almost everytime its a different code when i have it read has anyone else had this problem, if so how did you fix it?
Old Aug 17, 2005 | 05:17 PM
MaxKlinger's Avatar
What are the codes you're getting? Obviously there's some kind of problem here, and it would be mighty helpful to know what codes the ECU is puking up.
Mine used to come off and on for a while, but it was always the same code, 0203, which is an oxygen sensor. I replaced the sensor. I haven't had a code appear since.
Old Aug 17, 2005 | 07:09 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
0203 = Closed Throttle Position Switch
oh and btw, CEL flashing on and off = heavy misfire
your probably killing your CAT
Old Aug 17, 2005 | 07:14 PM
gtmuggs's Avatar
In what way could i be killing my CAT, also what do you consider flashing off and on it comes on for a 2-3wk period then goes off for about the same time.
Old Aug 17, 2005 | 07:20 PM
killcrap's Avatar
HIGH HC's but anyway.... flashing could be caused by a couple of things.
1)faulty fuel injector/circuit
2)faulty igniton coil/circuit
3)mechanical damage
remember, electronics dont like the following
Over amperage
Over voltage
and Over heating.
Old Aug 17, 2005 | 08:23 PM
4x4Max's Avatar
I have the exact same thing and im wondering WTF the problem is, i dont have money to waste on sensors i might not need.
Old Aug 17, 2005 | 09:05 PM
nfafan's Avatar
As I understand it, the misfire would be dumping un-burnt gas from the cyl into the exhaust stream and on into the Cat Converter, not good. OTOH, an excuse to get a high-flow cat.
Old Aug 17, 2005 | 09:11 PM
Supermax95's Avatar
when they say flashing they mean on for a second, off for a second, on for a second and so on. Your most likely not misfiring cuz your cel is not flashing. Its turning on for a few days then off again. I would just pull the codes when its on and fix whatever that problem is.
Old Aug 17, 2005 | 10:41 PM
MaxKlinger's Avatar
It was probably 0303 instead, this was some time ago and I don't have the chart memorized. It's not all that relevant anyway.
My CEL was going on and off on the order of every few days, not an intermittent flashing. I'm under the impression that GTMUGGS is also seeing the CEL come on and off at a similar frequency and is not experiencing a heavy misfire.
GTMUGGS, check the codes and let us know what you find out. The sticky for how to pull the codes and what they mean is here:
http://forums.maxima.org/showthread.php?t=104931
Good luck!
Old Aug 18, 2005 | 04:25 PM
gtmuggs's Avatar
well im glad to find out its not flashing but i will have the codes and post them the next time the light is on right now its not on. I know a few times before the codes before i think was the throttle positon sensor, and the knock sensor which im going to check the knock sensor this wk end but i really appreciate all the help
Old Aug 18, 2005 | 08:59 PM
MaxKlinger's Avatar
Just as a thought, try to pull the codes now anyway. Sometimes the ECU stores codes even if the CEL is off. This isn't always the case, but it's worth a shot.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
