Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Car won't start! (https://maxima.org/forums/4th-generation-maxima-1995-1999/318918-car-wont-start.html)
97PearlWhiteSe Aug 27, 2005 02:23 PM
Car won't start!
Hi there I just went to get some food, and went to tried to start the car, but it won't :hyper: . It cranks but won't kick over. Now it wont even crank, but the battery is at 12.3 volts. Any1 know what the problem could be? Starter maybe?
KiLIAkLoWn Aug 27, 2005 09:02 PM
My car acted up today with a similer problem but mine wouldnt turn at all. It ended up being the starter, i gave it a whack and it cranked. Must of been jammed, b/c now it cranks right up.
Batxel Aug 27, 2005 09:11 PM
I have same exact problem. It was barley cranking but now its getting nothing. I bought a starter off of ebay last month and will try put in the morning. I checked the codes and got 01 02 (MAF sensor) could that stop it from starting?
edit: It turns it was the starter
1996blackmax Aug 28, 2005 08:13 AM
97PearlWhiteSe try hitting the starter with something to see if it cranks as KiLIAkLoWn suggested. You can also take it out and go get it checked at Autozone or Kragens.
Yes it will. Have you done any work around the MAF or the wiring around it? Have you re-oiled a filter?
Do yourself a favor and replace the starter as soon as you can.
killcrap Aug 29, 2005 06:14 AM
since the car does crank, check for spark, get a spark tester. then if you have spark, check for fuel with either a noid light or fuel pressure gauge
ghdtpdna Aug 29, 2005 07:01 AM
my car wouldn't start for like 3 minutes
i never had a problem since.
should i get it checked up or something
97PearlWhiteSe Aug 29, 2005 07:50 AM
Well I'm having my car towed today to my mechanic. It still won't crank...It makes some sort of clicking noise now. I tried hitting it with a hammer...still now luck. How much do you guys think it will cost to get a new starter?
KiLIAkLoWn Aug 30, 2005 09:44 PM
i just got mine replaced today. Cost me 500. 264 starter + 180 Labor + tax + shop fees.
GoalieKeg Aug 30, 2005 09:52 PM
That sounds like either an alternator problem or a battery problem...but it could possibly be the starter too...because you say that the car won't even crank. Are your interior/clock lights going dim? Do your HID's turn on/off, or flicker? I'm currently getting my alternator replaced per the 97-98 TSB alternator recall. I'm running an optima blue top battery that is keeping my car alive for my trips to classes, I can't even run my stereo, and can barely turn my a/c on...I also have a trickle charger, so I throw the battery on that every night... :grinno:
GoalieKeg Aug 30, 2005 09:55 PM
For a STARTER? That's like 2 bolts, a few wires, and you're done. No offense, but you just took it in the a$$ man from the shop that you took your max to.
Batxel Aug 31, 2005 06:51 AM
^^^^^^ :wtf: It takes at most a half an hour to change the starter. They really went overboard on that labor charge.
1996blackmax Aug 31, 2005 05:15 PM
I paid around $160 dollars for it at Autozone, came with a lifetime warranty. Took it home, put it in, no more problems :). Not hard to put in at all.
