Stillen Cat-back Exhaust 97-99 Maxima
What do you guys think about STILLEN CAT-BACK EXHAUST for my max? DOes it sound good? Is the quality good. I've been out the game for a while help me out.
Way too much money for what you get and it will sound like a$$ with a y-pipe or b-pipe with no resonator. If you're going to spend that kind of money I'd either go Cattman or cutom setup (I went custom with a Borla muffler)
Where can I find a Cat-back Exhaust from Cattman, and/or BORLA???
http://www.cattman.com/ for the catman, and borla doesn't make an exhaust system, bhmax was saying he went to an exhaust shop ( found in the phone book call around they all vary in prices ) had one custom bent for his car and used a borla muffler for it.
i have the stillen rear section and everything else stock
it sounds like a dream, you only mess with rasp when you start changing the b-pipe and Y but some might believe....... performance > rasp |
Actually I didn't go to an exhaust shop I bought the muffler as well as a budget b-pipe because I wanted mandrel-bent and no shop does that around here. Then I had a piece bent to fit between the muffler and b-pipe with a flange welded on one end to bolt to the b-pipe, and the other end welded to the muffler, which turns the Borla muffler into a bolt-on. So now the exhaust still remains easy to take apart if I ever have to drop it to do work under the car.
© 2024 MH Sub I, LLC dba Internet Brands
