Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   CEL flashing; i don't know why (https://maxima.org/forums/4th-generation-maxima-1995-1999/333164-cel-flashing-i-dont-know-why.html)
slicey Dec 10, 2005 12:46 PM
the CEL is flashing while i'm driving. i don't mean it's in diagnose mode. i replaced CTS, then cleared CEL codes. afterward, this is when i started getting the weird behavior. any ideas, gentlemen?
Kevlo911 Dec 10, 2005 12:46 PM
http://forums.maxima.org/showthread.php?t=104931
njmaxseltd Dec 10, 2005 01:09 PM
You have a misfire.
MDeezy Dec 10, 2005 01:22 PM
multiple mis-fires
themills Dec 10, 2005 09:39 PM
I only had one, and it was flashing.
f550maranello2 Dec 10, 2005 10:17 PM
you might have left it in self diagnosis mode... happened to me a couple of times lol
slicey Dec 11, 2005 03:21 AM
the CEL flashes about 20 times, then stops for about 10-15 sec, then flashes again. does a misfire have a code? because my engine is running CRAPPY. engine very shaky/rough running. have to drive w/ tach higher than 3000RPM to make most of roughness appear to go away, until RPMs go under 3000 again. arghhh. if bad fuel injector, is code for that problem? i did replace all on rt. bank over 3yrs ago so maybe lt bank having a bad injector or two?
themills Dec 11, 2005 01:17 PM
Go to autzone, and when the light blinks, press read. Stop guessing because you won't be happy if you guess 500 dollars worth of unessecary repairs. If you have a bad injector, I believe it can throw a misfire code, and a bad misfire is USUALLY the culprit for a blinking SES.
