car stalls in reverse in cold weather(sometimes)
Recently in the cold my car likes to stall in reverse. As soon as i shift into R (auto Transmission) it completely shuts off the dummy lights come on. Then i have to put it into park and start it again and it works fine. Any ideas what could be causing this im pretty sure that the tranny is perfect. I have a stage 2 Valvebody from jeff at maximum tuning. I also have a geforce ecu. The shifts are perfect and show no signs of sliping. I have the egr code 0302. Im not sure if this would cause the problem im having.
Originally Posted by DcMaN
nope no CELS except 0302 the egr valve. Are bad drop resistors found often in our cars ? THats the thing found on the driver side strut tower right.
Oh, I'm also not sure if a clogged EGR passage (which is why you have 0302 most likely) would cause an idling problem... it may... I'll need to look into how/when the EGR valve is supposed to open up.
ive replaced the solenoid twice and still no luck so i guess i have no choice but to remove the intake manifold hehe. It is actually a weird proble, at stops sometimes the idle raises to about 900 and stays steady their untill i come to another complete stop. Sometimes it constantly stays on 900.
The idle problem is sounding more and more like a sticking IACV/solenoids in the IACV. Just pull it all apart and clean it... (intake cleaner or whatever)
oh reaalllly i did not know that sir. Is their a guide ?
/End of Guide
Just kidding.. no guide that I know off, but I can take a peek tomorrow (I have a spare one in the garage that I'm too lazy to go get).
Just shoot me a PM to remind me.
is their a screw like fitment on the plastic part of the iacv under neath that gold plate ?
There are a few screws on the other side with all the connectors that you can pull and clean.
Lakersallday24
06-16-2019 01:35 AM
MaximaDrvr
08-19-2015 08:20 PM
Derrick2k2SE
08-12-2015 06:47 PM
kirkhilles
08-08-2015 10:53 AM
