New BBK installed with my 19's on. are these to close for comfort??? (PICS INSIDE)
13 stillen rotors (Dba Gold), 30mm 300zx TT calipers with hawk hps pads, mounting brackets, hubcentric rings, SS conversion lines, ate blue racing brake fliud, 19" Axis se7ens.:ben:
Do these appear too close to any of you BBK folk, or any of you in general? it drives fine but makes me nervous to know how close they are:slant: , they clear my G35c's nicely. http://www.cardomain.com/member_page...9_129_full.jpg http://www.cardomain.com/member_page...9_127_full.jpg http://www.cardomain.com/member_page...9_128_full.jpg http://www.cardomain.com/member_page...9_132_full.jpg http://www.cardomain.com/member_page...9_130_full.jpg http://www.cardomain.com/member_page...9_131_full.jpg |
looks good man so 300zx bbk do clear g35c's
also you should get a 5mm spacer that way you dont have to get longer wheel studs an the rim will be further away from the caliper |
That should be fine. Even OEM fitments are closer than that.
I hope you're enjoying the BBK power! I still have brackets and rings if anyone is interested! :D |
:D:D
http://img16.imageshack.us/img16/156/11212930ro.th.jpg
NICE! :drool: I wouldnt worry about the clearance. Looks like you have plenty.
dont mean to jack your thread but jeff92se i have a question for you i've read alot about doing the 300zx caliper converion and I wanted to know a few things such as :
in order to installl 300zx calipers and 300zx rotors you have to : get 30 mm 300zx calipers and 300zx stock rotors mill the stock rotors down 3-4 mm and the 300zx caliper will bolt up to the stock maxima location. do you need a conversion brake line? and do you need hubcentric rings? And in order ro do the true BBK : you need 300zx 30 mm calipers 13 inch stillen rotors to mustang cobra rotors, mounting brackets, hubcentric rings, and conversion brake lines? |
Thats pretty close,....
Mine were that close, http://img97.imageshack.us/img97/274...arence26ew.jpg so I threw on some 5mm's just to be safe and that gave me plenty of room. |
wow, Flavor! that's a close setup!
Yup, it had me worried. The wheel spun fine with no rubbing, but I felt uneasy with it, so I put on the H&R 5mm spacers. |
Wow, yeah that is a lot closer...:ugh: where to get those spacers and did you have to get londger studs or shoudl i not worry about it |
I got them from another Org member.With them being 5mm, there was still plenty of threads left on the studs. Anything over the 5mm and you should get longer studs, 8 might be okay, but I wouldnt risk it. |
Is this a picture of your BBK right now?
what rotor and which brackets did you use to fit that rotor with the calipper? http://memimage.cardomain.net/member...9_127_full.jpg |
yes that is my current BBK, my friend has the box they came in and i cant remember the name right now, i bought them from max4speed he says he got them from stillen, i got them from him for 104 bucks. i will find out and post the name.
The ones I've been telling you to get. Mine. :D
i got it from max4speed, he said he got it from stillen but upon looking for it i cannot find it, so i still have the box but im at work so when i find out i will post, i think it started with a P...
thank you for all the info i think this summer im going to do the 300zx 30 mm calipers and the 300zx rotors.
say i were to get brembo 300zx rotors can i have those milled down also or can you not have brembo (drill and slotted rotors) milled down? also what is the benifit of have the "true bbk"? like whats the difference in have all 300zx stuff and having 300 zx calipers and 13 inch rotors? |
i believe that the 300 zx rotors are smaller, ther are 11.5" i think so you got your stock 10" brakes, 11.5-12 300zx, or 13" rotors... since your already having to do everything id just get teh 13" rotors like i did, i had to mill just a tad off for them fo work, i don't believe you have to for the 300zx rotors.
The 300z and maxima rotors are the same size in diameter. If you use 300z rotors you will have to have them milled down a bit. |
so even using 300zx rotors you have to mill them down? i guess since you have to its best to just go with the 13" rotors..
on cardomain i can't remember whos maxima but they have pictured comparisons between the 13" rotor, 300zx rotor and our stock rotor.. its pretty cool actually, after seeing the pics i definatly was glad to get rid of our peice of stock crap brakes. |
well it depends how much money you want to spend because if you just dl all 300zx stuff you dont have to buy the brackets and the bigger rotors
well if your already spending the money to upgrade to a BBK do the true BBK, rotors are cheap and the brackets don't cost an arm and a leg either. maybe 75 bucks extra for the 13 rotors.. just my opinion i guess.
It depends on how much you get the calipers for. Thats seems to be the most expensive part. The rotors you can get in the G/D for the 04 maxima and the Cobras have been found for pretty cheap also. All setups require new lines, the 300z require conversion lines and the BBK's I believe need longer lines. i was going to do the BBK, but I bought the wrong calipers, so just went with the 300z setup. |
im my case i think im going to just do the 300zx calipers and rotors because i dont want to buy the bigger rotors and the bracket.
also my rims are 18 inch and i used the matt b measurement and i need 1/2 inh of spaceing so i'll have to buy londer studs and spacers |
also my rims are 18 inch and i used the matt b measurement and i need 1/2 inh of spaceing so i'll have to buy londer studs and spacers Using the 300z calipers may require you to use spacers anyways. The offset and spoke design of your wheels will determine that. Im using a 5mm spacer on my setup. |
FTW!!!!!:bowdown1: |
no what im saying is all im going to do is buy 30 mm calipers and stock 300zx rotors have then milled and then get the conversion brake lines and install them. i know with the rims I have I will have to buy wheel spacers and longer studs
okay the 13" rotors are sold by stillen, they are Dba Gold's...
these 13" rotors sold by stillen, Dba Gold's, they are for the cobras right?, do they need to be milled down? and plus.....does it fit perfectly with the 4th gen?
If it clears it clears, the wheels is not going to flex nor the caliper is going to move around.
I wouldn't say that. There is some flex. It's the nature of metal. You cannot 100% eliminate flex.
my question was if those rotors needed to be milled down with the brackets., not if it fits it fits.
those cobra rotors dont need to be redrilled or anything do they? |
Ugh. My question is why would I design a bracket that requires you to mill down the rotors when I can design that out from the get go???
those cobra rotors dont need to be redrilled or anything do they? Alot of your questions can be answered using search. |
I had to mill the rotors a tad, like any other 13" rotor, whether or not these were made for the cobra or not im not sure. but they fit great and stop good. BTW no i didn't have to redrill holes to fit my lug pattern. just use the hubcentric rings and mounting brackets everything bolton on with ease.
Actually you DON'T have to mill the 13" cobra rotor for my bbk. But since I didn't design this kit around a Stillen unit, it might have been necessary. My kit is designed around the dimensions of an OEM 13" Ford Cobra rotor
thats true. my friend who put them on said that he didn't have to do it to his cobra rotors. sorry about that... it was necessary however for my rotors. |
I'm not trying to beat you down or anything but miss information spreads alot faster than correct information. So if I can clarify something, I will try. I also have to write it in the most clear and easiest way possible to avoid confusion. Unfortunately some tact gets lost in there somewhere. Nothing personal.
i understand, i wasn't offended or anything, i appreciate your honesty and your willingness to help, really thank you if it weren't for your help i wouldnt' have had my BBK. I LOVE it. i think it stops faster than my R6. :spin: |
question, when using the stock 300zx rotors I know you have to get them milled down 3-4 mm I was just wondering where you have to get them milled down
http://i7.photobucket.com/albums/y28...x/untitled.jpg |
| All times are GMT -7. The time now is 10:28 AM. |
