Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   All 4 Turn Signals won't work ---- Light bulbs okay, Fuse okay (https://maxima.org/forums/4th-generation-maxima-1995-1999/341787-all-4-turn-signals-wont-work-light-bulbs-okay-fuse-okay.html)
Hajime Feb 12, 2006 05:56 PM
All my turn signals don't work all in a sudden, I checked the light bulbs in all 4 compartments and found their tungsten didn't melt.
And then I also checked the fuse box, but I don't really see there is any fuse responsible only for turn signal, so I checked "fr fog", "L head lamp", "R head lamp", and everything else related to light and they are all okay!
Can anyone please help me to fix this problem. I know I will get pull over soon if I don't turn with my lights on somehow!!!
Thanks x1000.
MDeezy Feb 12, 2006 06:00 PM
If you hazard light plugged in? Your turn signals wont work if its not plugged in (found this out the hard way)
Hajime Feb 12, 2006 06:02 PM
Hazzard Light not working too
Thats right. My harzzard light is not working neither.
So what do you mean by "plugging in harzzard light"?
Thanks:flame:
MDeezy Feb 12, 2006 06:03 PM
if you pull out that part of your center console, there is a connector to plug into the back where the hazard button is, if its not plugged in your turn signals wont work.
Have you take apart you center console recently?
Hajime Feb 12, 2006 06:06 PM
I haven't opened the center console recently.
But I don't know why it won't work.
But thanks anyway, I will try to open the console later after dinner to see if it works.
Cross my finger.
matts95max Feb 12, 2006 06:12 PM
check your blinker fluid levels?? that my have nothing to do with it..(don't flame it was a joke. ha ha)
MDeezy Feb 12, 2006 06:15 PM
OT:
Hey how much of you max you were parting out do you have left? I may need a few more parts.
XoPtOn Feb 12, 2006 07:50 PM
do u get the ticking noise when you put your blinker on?
MaximaSE96 Feb 12, 2006 07:53 PM
what about the flasher relay in the fuse box
Hajime Feb 12, 2006 10:36 PM
Not at all. I just get nothing when I put my blinker on.
No light, no signal, no noise.
Hajime Feb 12, 2006 10:38 PM
I checked the hazzard button, the connector is securely plugged in. So I don't think is this causing the problem.
Any other suggestion??
I really don't want to go out and pay the extra labor fee.
Delvin Feb 12, 2006 10:40 PM
Its kinda hard for the hazzard light switch to become unplugged on its own. I've ran into a few that didn't want to come off with force. From what you are describing I'd put my money on the hazzard light switch. Ran into the same problem on a couple of other cars I've worked on.
XoPtOn Feb 13, 2006 08:05 AM
i had the same problem last year, trust me its the flasher relayer, its under the dashboard right by your knee, i went to a nissan dealer and just bought one and replaced it, its a really small black box and you just connect a wire to it.
nismos14 Feb 13, 2006 12:53 PM
I have a switch if you end up needing it. But I would replace the fuse, even if it doesn't look burnt, at least you can be sure. Sometimes they can be partially burnt.
DAVE Sz Feb 13, 2006 09:25 PM
Hazard fuse????????????? There are 2 or 3 fuses that can make the turn signals not work. However with no clicking a relay might be the problem.
nismos14 Feb 13, 2006 09:56 PM
Besides the hazard one, which others can it be? Also what can cause the Hazards alone to not work but the signals to work fine? Anyone know this?
gotjuice Feb 14, 2006 04:07 PM
$50 to $60
:banghead: It is called a blinker relay which is located where someone said a your right knee sitting in drivers seat under dash. if blinker relay is damaged it would cause no sound no blinking for both the hazards and turn signals..100% it has happen to me once.However i have seen others on an led web site for less money $13 dollars or so...
TLMNICK Feb 14, 2006 05:02 PM
Check the simple things first... there is a fuse dedicated to signals, which also operates your hazard lights. check ALL the fuses until you find a burnt one.
