RPM's go down when I apply brakes!!!WTF??
Hey guys, just as the topic states, my RPM's go down everytime I apply brakes standing(not moving)....My car is a 5 speed 98 SE with around 106k miles on the clock. Regular maintenance, cleaned TB and IACV a little while ago. Any help is appreceated. Thank you!
привет бандит
alternator is struggling everytime u press the brake, does it do teh same thing when you hit the defroster switch?
yeah, the same thing happens to me too. but i also have other problems; my rpms raise when i turn on the ac/heater to the auto function, rpms raise when i turn the wheel, and the heat comes out to the floor when the heater is off. so yeah, my whole car's messed up after the accident. so sad..
^^ those are all normal, so i hope you are joking.
the brake booster is connected to the intake, so you are using up vacuum when you apply the brakes, its called vacuum assisted brakes! if you didnt have this you would need some strong legs to stop the car. |
That's not as bad as your RPMs going down when you press on the accelerator. Happened to me once ... it was water that got sucked up into the air intake (drover over a huge puddle).
u could also try a grounding kit too
But I heard that grounding kits doesn't do much good even make it worse? Is it true?
Originally Posted by eclypsecl
привет бандит
Thats because everything is belt driven off the crank.:shiner: |
yo ruski power thats my only advice
RPMs do go up when you turn wheel or put a load on alternator, because ps pump and alternator take their power from the engine... but my rpms do not drop when i hit the brakes (and if rpms do drop it's so low that the tach doesn't register it)...
All of these are normal. If you don't want air coming through your vents at all when you're driving, hit the recirc button. |
Umm my rpm's go down when im moving when i press the brakes. Don't worry about it
my rpms stop moving when the car is off, is that normal? I think something is broken :)
hitting the brakes slows you down.. thus your rpms go down ;) fake edit: all the things you guys were saying are normal.. A/C, turning wheel ect. |
Thats weird. My RPMs go up when i push on the accelerator. OH MY GOD IS MY CAR IS GOING TO EXPLODE?!?!?!?!?!....
What can i do? Anyone? PLEASE HELP NOW!! EMERGENCY. I wonder if some people on the .org ever get laid. |
Its like a little boys nursery schooll here. No offence.
same things happens to me, Nothing unusual and your car is perfectly fine. I also have the issue of the idle going down when I'm sitting at the light with the brakes on. |
not to hijack this thread, but recently, my cars RPM has been wandering. after going on the freeway, and stopping at a light, the needle drops to zero and the car dies, dummy lights come on.
RPM daily has been around 500, and when i step on the accelerator, the rpm goes up around 400 with a deep purr and starts moving again.. im new with max's so any help is needed :gotme: |
The only time my rpms dipped to stall was when I filled the car up at some billy bob gas station. Dealership said it's not the problem...I showed them..and my clothes..full of gasoline.
| All times are GMT -7. The time now is 11:30 PM. |
