Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   I can't search, so excuse me....transmission leak (https://maxima.org/forums/4th-generation-maxima-1995-1999/354040-i-cant-search-so-excuse-me-transmission-leak.html)
Shannon and Ian May 13, 2006 01:10 PM
My 97 Auto is leaking tranny fluid. It is not coming from the axle seal, but looks to be where the block and transmission mate. It is intermittent. you may see a puddle today then not see it for a few weeks. Where do I look. TIA.
EdgeVetto May 13, 2006 04:25 PM
you can search. google advanced search only in forums.maxima.org
surfman21 May 13, 2006 05:36 PM
stfu edge, i hate all you ***s that bust on ppl for this...dont post replys if you dont have something positive to say
shannon and Ian....Usualy this problem is assosiated with bad differential side bearing(need tranny rebuild), possibly somthing else you need to post pics. To check if your bearing has gone, get under the car and try to move the axle (by where it connects to the tranny) up and down. If there is significant play and fluid spills out, you're one of the many owners with this defect....congratulations, you need a tranny rebuild
96blkonblkse May 13, 2006 05:54 PM
that problem was on 5spds only, but it doesnt mean it cant happen to auto's. the leak may look like its coming from where the tranny meets the engine but it is more then likely leaking from the drivers side driveshaft where it goes into the engine. Your bearing could be bad(Not properly shimmed from factory) and causes excessive preload on the bearing which causes it to go bad and in turn stretches the differential oil seal which is more then likely the leak you are seeing. I know this because this is what mine is doing and the only way to fix it is to replace the bearing which involves tearing apart the whole tranny to replace a 40$ bearing.
Shannon and Ian May 14, 2006 04:13 AM
That makes sense, I did not look at the passengers side axle seal.....BRB!
BTW, I do not see the google advance search button?:slap:
dgeesaman May 14, 2006 06:07 AM
nevermind.
Shannon and Ian May 14, 2006 08:55 AM
Originally Posted by dgeesaman
nevermind.
It was transmission fluid.
TimDawg May 15, 2006 08:37 AM
Thanks, I'd forgotten about that trick. Why doesn't the search on this forum work? I emailed the webmaster and never got a reply. The easiest way to do this is type the following in the google search:
site:forums.maxima.org <search term>
replace <search term> with something like brake or spark plug or whatever you want to know about.
dgeesaman May 15, 2006 08:41 AM
Plus, if you require google to also match the string
"Maxima.org Forums > Maxima Discussions > 4th Generation (1995-1999)"
you'll restrict your results to the 4th gen forum. Works very nicely in the classified section, which isn't searchable for anyone.
Dave
pmohr May 15, 2006 11:37 AM
You need to donate in order to use the site's search feature.
Shannon and Ian May 15, 2006 02:18 PM
Which is something I will have to do becasue I took over my wifes Max fulltime while her job gave her a company car. My NX will be a show beast now.....:easter:
