Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   BBK Pro's.. step in (https://maxima.org/forums/4th-generation-maxima-1995-1999/354584-bbk-pros-step.html)
brooklynK3Y May 18, 2006 12:23 PM
BBK Pro's.. step in
Ok, i've been reading a thread that was old, and a guy stated that you cannot use 30MM Z32 Calipers on 13" cobra rotors because they are 26mm thick(thats what was stated).. Is this true? Do i need to purchase the 26mm calipers, Because if so, then i'll just go with the 300zx rotors..
Jeff92se May 18, 2006 12:25 PM
Did you not read the reply from the maker of these kits?
Does this look like you can't use the 30mm calipers?
http://img177.imageshack.us/img177/5125/trackpic3lg.jpg
brooklynK3Y May 18, 2006 12:42 PM
Im just asking what i read, noone responded to the guys statement, and noone states what size calipers they have, they just say 300zx calipers. So i was asking a simple question.
Jeff92se May 18, 2006 12:49 PM
http://forums.maxima.org/showpost.ph...4&postcount=34
FROM JEFF92SE Although I've never tried it, I don't think it would fit well. The 30mm calipers have more offset room and is thicker to accomodate the Cobra rotor width.
Quote:
Originally Posted by Kevlo911
Can I use the 1990 300zx 26mm calipers with the cobra rotors?
__________________
86maxima96 May 18, 2006 01:14 PM
Originally Posted by MaxFanatic
I want to be spoon fed
i'm sorry, but seriously, just look around a bit before giving up.
brooklynK3Y May 18, 2006 01:26 PM
That was not needed, asked a simple question, and dicheads come in the thread to boost there ego. :thumbsdow
Flava_24/7 May 18, 2006 07:30 PM
You must have read wrong, show me this thread you are refrencing to.
You cannot use the 26mm calipers for the BBK setup. The setup was designed around the 30mm calipers.
