Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Help! Car Won't Start (https://maxima.org/forums/4th-generation-maxima-1995-1999/356946-help-car-wont-start.html)
goobergo Jun 8, 2006 06:44 PM
Just went out to start the maxima 10 mins. after driving it and it would not start up I turn the key and I get power but I turn to 'start' and absolutely nothing happens. I don't know what to do. Here are my trouble codes:
0403(Throttle Position Sensor), 0304(Knock Sensor), 0305(EGRTS), 0401(IATS)
99grnmaxgxe Jun 8, 2006 08:34 PM
Dead battery? :gotme:
SBman182 Jun 9, 2006 08:46 AM
alternator?
f550maranello2 Jun 9, 2006 09:22 AM
its the ignition switch.. if u turn the key and absolutely nothing happens... jiggle it when you are trying to start it...
then check ur batter
buntypatel Jun 9, 2006 10:54 AM
I would think its alternator
clive Jun 9, 2006 03:30 PM
Like f550 said, it is either the ignition switch (part inside the column cover) or possibly the throw-out solenoid on the starter motor.
MDeezy Jun 9, 2006 03:58 PM
It could be various different things. If you are getting nothing when you start up it could be:
-Dead battery
-Ignition switch
-starter
v
-Check the battery, try a jump
- try tapping the starter while cranking
- check the ignition switch.
A situation like this has happened to a friend, I tapped the starter while he was cranking fired up. The Gear is the starter could be stuck and thus not moving at all.
LTU_max Jun 9, 2006 04:50 PM
If auto try putting it in Neutral and starting.
sickmen Jun 9, 2006 04:54 PM
Try to tap the starter with a hammer (don’t hit it with full force just tap!) and if it starts then you need to disassemble and repack the starter. It only cost a few bucks for gear grease. Maxima has bad gear grease in the starter motor. Don’t waste your money on any parts before trying out this method.
