Windshield Wipers Don't Work
Windshield wipers don't work and it's not the fuses. Fuses are okay. Could it be I need a new wiper motor?
Also, the A/C and heat do not work as well. No air blows out and I don't hear the compressor kicking on. For the A/C, could the freon be empty? Thanks. |
For the air problem, does the blower motor work on high and no other setting? If so, it's the blower motor resistor. About a $40 part, and ridiculously easy to replace.
maybe u have a bad relay and not a bad fuse?
check the wiper control by the passenger relays. btw: it wouldnt be the motor resistor b/c even at speed 1, 2, 3, the a/c compressor would still kick in. i had the same issue before i changed my resistor. it may actually be a leak or the compressor is shot. |
For the wiper blades, do you hear the motor running? If you do, you probably screwed up the linkage!
A/C compressor does not kick in on any setting (digital climate control). I can turn on the A/C or the heat, put the fan on settings 1, 2, 3 or 4 but no air blows out of the vents and I don't hear anything kicking on.
For the windshield wipers, no engine running. |
When you say no engine running, do you mean your car's engine???
I'm talking about the wiper motor.
I'm talking about the wiper motor. |
Check fuse/relay, connection to motor.
| All times are GMT -7. The time now is 08:27 PM. |
