Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Torque it to specs, or just til it's tight? (https://maxima.org/forums/4th-generation-maxima-1995-1999/360817-torque-specs-just-til-its-tight.html)
maxfanfromohio Jul 11, 2006 07:56 AM
I have done alot of different things to my car, and I don't think I have ever tightened any bolt to specs.
How about you guys?
Kevlo911 Jul 11, 2006 07:58 AM
Depends on what it is. Some stuff i do hella tight or just tight. :)
f550maranello2 Jul 11, 2006 07:58 AM
i use german specs..... goodantight :wall:
tavarish Jul 11, 2006 08:01 AM
depends on what it is.
Timothios Jul 11, 2006 08:03 AM
:rofl: That is awesome! I must use German specs, too!
matty Jul 11, 2006 08:27 AM
Depends on what it is. Manifold bolts, flywheel bolts, clutch bolts, need to be perfect, but alot of the other bolts dont need to be to spec.
-matt
maxfanfromohio Jul 11, 2006 08:35 AM
-matt
I haven't changed any of those, so, so far so good.
RedfoxXx Jul 11, 2006 08:43 AM
one thing not to over torq is bolts that hold banjo fittings, I snaped one ounce, (REAL EASY TO DO!) they can be a pain to replace and remove the old blot also,
other thing you got to be carful on under-torqueing (moving stuff liek the bold on ur UDP)
haveig a haynes manual and a torque wrench can save you alot of trouble to do a greta job, but on little jobs I would not bother
dgeesaman Jul 11, 2006 08:51 AM
It depends, in my case.
Most torque specs in the manual are simply the max allowed for that size of fastener. Suspension bolts, brackets, various mechanical stuff tends to be that way. I have done enough with a torque wrench to have a feel and so I don't use a torque wrench most of the time.
Any situation where you're crushing something (banjo bolts w/ copper crush washers, manifolds with gaskets), or tightening a flange with several bolts (clutch cover, intake manifold, exhaust manifold), then you need to observe the torques and tightening pattern closely. I always use a torque wrench for that, since incorrect tightening can cause warpage or leakage.
Dave
i30ds Jul 11, 2006 10:00 AM
I try when ever I can. Some times the specs are too low for my torque wrench and some times I can't get the wrench into tight areas.
D-Bo Jul 11, 2006 10:03 AM
:werd2: I try to use it whenever possible.
ONE BAD Maxima Jul 11, 2006 10:34 AM
I do everything to torqe specs...... Why.... because it is easier to get off the next time around...
Fr33way™ Jul 11, 2006 11:00 AM
I have never used one. I usually follow the snug+1/8th rule. I have not done major engine/tranny/clutch work however and for those I will be buying a tq. wrench.
i30ds Jul 11, 2006 11:05 AM
Especially for clutch work.
BigLou93SE Jul 11, 2006 11:43 AM
Haven't done anything truly major...but I try to use mine when I can.
