Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   How to replace steering wheel?(couldn't find in the stickies) (https://maxima.org/forums/4th-generation-maxima-1995-1999/361622-how-replace-steering-wheel-couldnt-find-stickies.html)
DuMKuH Jul 17, 2006 03:34 PM
Hey guys, I got the new steering wheel since my leather is all ripped off, got the puller, and I wonder if there is anything else I need and the procedure of replcing the wheel itself. Thank you.
Xyquine Jul 17, 2006 04:02 PM
please disable your airbag. Too many idiots dont and end up crushing their face.
DuMKuH Jul 17, 2006 04:13 PM
Yes I know that I have to disconnect the battery and wait like 10 min, but do I need any other special tools to do that? Like something to remove airbag or anything? Thank you.
DuMKuH Jul 17, 2006 05:20 PM
Anyone knows?
Kevlo911 Jul 17, 2006 05:20 PM
Check FSM or Haynes manual.
RA030726 Jul 17, 2006 06:09 PM
Tamper proof torx bit, size is t50. Napa has them for cheap.
IlyaK Jul 18, 2006 04:25 AM
Like I said in a previous thread...I did not use a torx bit for either bag. I took a larger flat head screw driver...lodged it into the screw...and undid them that way (I didn't have a bit). But defintly unplug your bags. I never had to worry about my bags exploding because although they are connected to the module...the module thinks they already blew (car is salvage and although airbags are brand spankin new module things it's the old bags that already blew). You will also need a 19mm (or 17mm?) head to unscrew the actual steering wheel. The Haynes manual says you need a special tool to seperate the wheel from the column...but if yours is hard to come off...just wiggle it from side to side (hold you hands at 3 and 9 o'clock) while pulling lightly and it should come off within 20 seconds of wiggling. When you put your new one on...make sure you are putting it on in the same position as the old one because it's got "grooves" that it slides into...so you should put it in the same position as the old one.
chillin014 Jul 18, 2006 08:18 AM
does the 97 wheel fit with the 95 bags and all that? i just want to swap..
Kevlo911 Jul 18, 2006 08:20 AM
Yes, 95-97 have the same airbag system. I think :wall:
semaj3708 Jul 18, 2006 08:21 AM
no 95-96 airbag can't be swapped with 97-99 steering wheel.
IlyaK Jul 18, 2006 09:47 AM
Correct...95-96 bags are square/rectangular and butt ugly. The 97-99 bags (and possibly early 5th gen) are the more sophisticated 4 'star' looking kind. The passenger one however, is the same I believe. If you want a 97 bag...just buy a 97 wheel and bag or trade yours for such a pair. Module should still work theoretically with either set.
chillin014 Jul 18, 2006 09:49 AM
alright, well as long as its plug and play thats cool with me. now to find a black 97-99 wheel....impossible
MaximaSE96 Jul 18, 2006 09:57 AM
GOTO phatg20.net and download the FSM
DuMKuH Jul 18, 2006 11:54 AM
Thank you! Got the Haynes already!
RA030726 Jul 18, 2006 12:37 PM
I have one but the leather was ripped. i took the top middle section out cuz i was going to redo it. i never got around to fixing it.
