CV's Do i need to remove the passenger one to change the driver one?
Just as the title states, do i need to take out the pass. one to "pop" the driver one out?
Also how hard is it to do the tranny seals where the CV's go in? and how much are they Also finnally, how much are Raxles, and do i get a Maxima.org discount. Thanks guys. OHH Car is a 98 I30 AUTO |
you do not need to remove the passengers side to remove the drivers side.
a raxle axle will probably be around $150-$1200. i paid $200 shipepd for my drivers side for a 2k2 maxima. |
It just pops out? cool thanks, any answer on the seals?
you will need to yank the axle out once you got it out of the knuckle. i never did the seals so cant help you out with that.
seals aren't hard, if you use something oversized (larger than the seal) and flat to pop it in you won't have to worry about putting it in too far. they are like $8 from nissan iirc (each side)
your can get a cv axle at autozone for 60 bucks if you give them your broken one
Ohh, when i take the seal out will all my fluid drain out too?
Thanks a ton guys |
No, your fluid is gonna all drain out when you take the axle out...
you'd better drain it first unless you'd like a face full of fluid. |
Alright thanks man
Just pry out the old seal with a screw driver. When you put in the new seal in try not to push it too far in. I made that mistake. Just keep pushing it in until it's even with the tranny. Anyway the toughest part for me was taking off the axle nut.
Wait, rewind, the fluids gonna drain out when i take the axle out?!, this didnt happen when i did my passenger one...
| All times are GMT -7. The time now is 01:53 PM. |
