Speedometer and odometer don't work
Is there a fuse I can check?
Everything else on the cluster works. |
no fuse. That potion is prob shot.
Or your speedo sensor or sensor wiring broke.
Dave |
how can I check that?
where is the speed sensor? |
its the meter fuse under the dash.
anything else I can check?
yep i remember when i had a taurus way back in the days and i had the same problem, i just went ahead and got the SHO odometer, just get a new one and if you want you can check the dealership and have them set your right milage... but best thing is to change
I just replaced the starter today, maybe I pulled out a sensor or something while I was under the hood.
Where is the speed sensor located? |
nope, the needle doesn't jump and the odometer doesn't move.
Where is the speed sensor located? The sensor itself is behind the starter, mounted on the tranny. Go back and inspect both of these. Dave |
Thanks, I'll try that tomorrow.
the little red plug i think
yeah there was a little plug behind the starter that was unplugged.
There's couple other threads saying remove the cluster and tighten everything on the back.
Jae |
Yea well I fixed it, it was unplugged near the starter
Same thing happened to me, it was a fuse in the panel under the dash. I can't remember which one off the top of my head, but it was definitly the fuse, check them all...
| All times are GMT -7. The time now is 09:26 AM. |
