Overdrive Light When Starting
I noticed that the overdrive light will come on when it starts. When it doesn't start the overdrive light is off.
Maybe my mind is playing tricks on me. |
Its on the shifter
If I try to start my car the light is off. When the light is on and I turn the key it is more likely to start.
Cold starts I always have to turn the key over more than twice. |
OD light always comes on when you start the car. Should light up for a second then shut off. If it's blinking then you have problem.
I noticed that the light would come on before it would start. When I turn the key and it doesn't start the light is off.
Light on = start Light off after key is turned = no start |
i think thats normal, your saying when the key in to the on position it comes on and then when you start it goes out. thats normal
Check AT-26 & 46.
If I said the car started and the light went off I wouldn't be posting something so stupid.
I said that the light will come on before the car starts. If I turn the key and the light doesn't come on then the car will not start. It's as if the car knows when it will start and when it won't. |
DL the FSM, read the pages that I stated and you should be able to go from there.
I've got two Gen 4 Nissans. My first was a '96 and our second was a '99. Both are GLE's - it's fun to see the differences, ... sometimes. Anyway, to my question: My '96 maxima starts up with overdrive in the OFF position automatically (orange light on) without me pushing any button, but my '99 Maxima starts up with the overdrive in the ON position automatically. Of course, I could push the 'button' immediately after startup in the '99 so that the overdrive is OFF ... which is now routine, but I'd like to have my '99 car start up with the overdrive in the OFF position - without me pushing the button - just like my '96!!
>>>>>>>>>>>>>>> Any thoughts out there?? How can I make this happen? Thanks, ..... |
Old thread bump Monday.
My 95 starts w/ it however it was last set. |
get a 5sp, problem solved
^^^^ kinda clever.
© 2024 MH Sub I, LLC dba Internet Brands
